Eye Posted January 11, 2011 Share Posted January 11, 2011 Hello everyone! Just moved from an R1200CM to a 2010 RT. Oh my God! Smooth! So I want to mount a GPS without cutting into the dash area. Besides, I like the unit near my left hand and up so I can see and reach it quickly. The handlebars are unaccommodating and the clutch reservior is a funky new design that has a little play in it. I'm not sure I want to mount a GPS on the reservior because it doesn't seem strongly anchored to the bar. Any suggestions? Thanks for looking, Mark Link to comment
DaveTheAffable Posted January 11, 2011 Share Posted January 11, 2011 - Go to "Bike Related Things" forum - Click on Search, Advanced search In the search field use +gps +mount +2010 You'll get LOTS of stuff. I LOVE mt 2010 RT! Link to comment
Mudman Posted January 11, 2011 Share Posted January 11, 2011 BMW makes a GPS mount that attaches to the dash cover with no drilling or cutting. It looks clean and uses the original screws for attachment. It's a bit pricey at $135.00 but it is solid and looks good. I like the GPS mounted mounted high and in your sight line of the road. No issues with the tank bag. http://ascycles.com/detail.aspx?ID=82511 Link to comment
Eye Posted January 11, 2011 Author Share Posted January 11, 2011 Thanks gentleman. The Techmount seems promising. Ride safe. Mark Link to comment
Chip Posted January 11, 2011 Share Posted January 11, 2011 I have a 2010 R1200RT and used the RAM Ball with U-Clamp. I mounted it on the left side handlebar. To protect the finish on the handlebar, I used clear tubing (found at most hardware stores) around the U-Clamp (had to warm up the tubing to get it on). After mounting the RAM Ball, I then touched up the nuts on the U-Clamp with black nail polish (same stuff I use on my helmet for nicks). When the Zumo isn't on the bike, the mount almost looks like it belongs there. When the Zumo is mounted, it's right where it needs to be and out of the way of reading any guages, etc. I like this better than the shelf mounts above/attached to the dash. Link to comment
Chip Posted January 11, 2011 Share Posted January 11, 2011 RE: U-Clamp. I used a slightly bigger U-Clamp than the one that comes with the Garmin RAM mount. Again, the U-Clamps can be found at most hardware stores. Link to comment
Eye Posted January 11, 2011 Author Share Posted January 11, 2011 Chip, Interesting suggestion. The standard black spacer for the RAM U bolt doesn't fit between the grip components but I forgot to consider the clear vinyl tubing as an alternative. I have used that before for other things and don't know why I didn't consider it. Thanks, Mark Link to comment
Teddy Posted January 11, 2011 Share Posted January 11, 2011 This is what I use on my 2010 RT http://www.motorcycleparts-hornig.com/BMW-R-1200-RT/Alu-High-grade-Steel/GPS-Mount-3.html Works very well & is in my line of sight. & Yes it also fits the 2010 model! Teddy Link to comment
Chip Posted January 11, 2011 Share Posted January 11, 2011 Chip, Interesting suggestion. The standard black spacer for the RAM U bolt doesn't fit between the grip components but I forgot to consider the clear vinyl tubing as an alternative. I have used that before for other things and don't know why I didn't consider it. Thanks, Mark I took a couple of pic of the setup. PM me and I'll send them. Link to comment
Eye Posted January 14, 2011 Author Share Posted January 14, 2011 Found this on the RAM site. Better price and shipping from the GPSZone. Matching it with the 6" arm and I'll be set up nicely. Works best on the top center bolt. Thanks again everyone. http://www.ram-mount.com/Portals/0/Skins/NationalProducts/images/367.jpg http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045051054055085/Default.aspx Link to comment
GRB60 Posted January 14, 2011 Share Posted January 14, 2011 I just ordered the kit from GPS Zone that includes the arm and diamond back plate. It should do the trick, along with a hard wire kit for my Garmin that I got on ebay. Link to comment
