Lawman Posted January 10, 2011 Share Posted January 10, 2011 The green and red lights on my Battery Tender Plus flicker continuously when I plug it in..It make no differnce whether I have the battery leads connected to the battery or not..Is it trash? Link to comment
pokorskij Posted January 10, 2011 Share Posted January 10, 2011 The answer can be found on the Battery Tender website: Link:http://batterytender.com/includes/languages/english/resources/Trouble_Shooting_BT_Plus.pdf I would contact them for a definitive answer. Link to comment
Jerry Johnston Posted January 10, 2011 Share Posted January 10, 2011 The manual says to connect the battery first then plug it into the wall outlet. Could this be your problem? Link to comment
Lawman Posted January 11, 2011 Author Share Posted January 11, 2011 The manual says to connect the battery first then plug it into the wall outlet. Could this be your problem? Nope...Just tried it...thanks though.. Link to comment
bobbybob Posted January 11, 2011 Share Posted January 11, 2011 Wally World has a cheaper alternative that does everything the BT does--$24.95 I have one--it brought my sulfated battery back from the dead! http://www.walmart.com/ip/Schumacher-SpeedCharge-Battery-Maintainer-and-Charger/13005742 The stores stock it. Reverse polarity protection, same features as BT. Probably the same guts. Link to comment
Lawman Posted January 11, 2011 Author Share Posted January 11, 2011 Works for me..thanks! Link to comment
Limecreek Posted January 11, 2011 Share Posted January 11, 2011 Do you have the BMW plug on the end of it? If you do unscrew the plastic cap and slide it back. Make sure each wire is firmly held in place with the terminal screw. I'll bet one of them or both of them are loose. Link to comment
Lawman Posted January 11, 2011 Author Share Posted January 11, 2011 Thanks Greg, I don't have the BMW plug on this one but I'll try to check my connections.. Link to comment
Lawman Posted January 11, 2011 Author Share Posted January 11, 2011 Called Deltran..A real live person answered on third ring. I described my problem. She confirmed the problem was internal and asked for the serial number . Serial number confirmed the unit was 7 years old. She said they would send me a complete new unit (clips and rings included) upon receipt of the old one and a check for $17.95 to cover postage and handling..Phone call took less time than it took me to type this post.. Link to comment
Glenn Reed Posted January 11, 2011 Share Posted January 11, 2011 Always good to hear about good customer service. It is rare enough these days. Glad to hear it all worked out to the good. Link to comment
Indy Dave Posted January 11, 2011 Share Posted January 11, 2011 SWEET! Thanks for posting the follow up. Link to comment
Rain Man Posted January 11, 2011 Share Posted January 11, 2011 Wow, a real person? With a replacement to boot??? What a breath of fresh air. Thanks for letting us know the outcome. Link to comment
Rinkydink Posted January 12, 2011 Share Posted January 12, 2011 Unheard of! Customer service...can this really be true? Link to comment
Lmar Posted January 12, 2011 Share Posted January 12, 2011 That's great customer service. Glad you are going to get it replaced. Link to comment
boatzo Posted January 13, 2011 Share Posted January 13, 2011 That is great service. Are the units MADE IN USA? Link to comment
Richard_D Posted January 13, 2011 Share Posted January 13, 2011 Deltran 801 International Speedway Blvd. Deland Florida 32724 Link to comment
Francis Posted January 14, 2011 Share Posted January 14, 2011 Bobbybob, will this charger you got from Sears also work on a Canbus system? Schumacher SpeedCharge Battery Maintainer and Charger Francis Link to comment
Firefight911 Posted January 14, 2011 Share Posted January 14, 2011 Bobbybob, will this charger you got from Sears also work on a Canbus system? Schumacher SpeedCharge Battery Maintainer and Charger Francis You can only use the hyper expensive BMW charger when running through the Canbus system. Just run a pigtail with an SAE plug direct from battery and charge through this. The advantage here is you can now also run a pump in case of flat repair. A pump will NOT operate off your Canbus socket. Link to comment
boatzo Posted January 14, 2011 Share Posted January 14, 2011 Phil is right on. IMHO, I would always go directly to the battery and stay out of the canbus, you will have a lot less grief. Link to comment
marcopolo Posted January 14, 2011 Share Posted January 14, 2011 Bobbybob, will this charger you got from Sears also work on a Canbus system? Schumacher SpeedCharge Battery Maintainer and Charger Francis ... A pump will NOT operate off your Canbus socket. I've been powering my CyclePump through my 2006 R12RT's accessory sockets (I have three) since Day One. And no, they are not wired directly to the battery. I do, though, have a wire running to my battery with an SAE plug which I use for a battery charger. Link to comment
Deek Posted January 15, 2011 Share Posted January 15, 2011 I've been powering my CyclePump through my 2006 R12RT's accessory sockets (I have three) since Day One. And no, they are not wired directly to the battery. I do, though, have a wire running to my battery with an SAE plug which I use for a battery charger. I too have run a dc powered air compressor off the BMW outlet without a problem. At least this was true on the '06 RT, I have not used the compressor on the '09 yet. I have the motor running when I do that. I do not think the bike's computer cares if the motor is running or not, but I do it anyway. I too have the SAE plug for my Battery Tender Jr but have not yet found a similar connector for the air compressor. That would of course take the BC out of of the equation. Link to comment
Lmar Posted January 15, 2011 Share Posted January 15, 2011 In response to: Poster: Deek Subject: Re: Battery Tender Plus Originally Posted By: marcopolo I've been powering my CyclePump through my 2006 R12RT's accessory sockets (I have three) since Day One. And no, they are not wired directly to the battery. I do, though, have a wire running to my battery with an SAE plug which I use for a battery charger. I too have run a dc powered air compressor off the BMW outlet without a problem. At least this was true on the '06 RT, I have not used the compressor on the '09 yet. I have the motor running when I do that. I do not think the bike's computer cares if the motor is running or not, but I do it anyway. wink I too have the SAE plug for my Battery Tender Jr but have not yet found a similar connector for the air compressor. That would of course take the BC out of of the equation. I ran a dc air compressor through the accessory plug when I picked up a nail in my rear tire last summer. I started the bike when I ran it and it worked fine. Link to comment
