smiller Posted March 28, 2012 Share Posted March 28, 2012 For the internal flexible lines did you use a product intended for total immersion in fuel? If you purchased the expen$ive BMW parts then you are in good shape, else you should use an appropriate substitute (available locally and still pricey, but of course you don't need much.) Link to comment
Limecreek Posted March 28, 2012 Author Share Posted March 28, 2012 For the internal flexible lines did you use a product intended for total immersion in fuel? If you purchased the expen$ive BMW parts then you are in good shape, else you should use an appropriate substitute (available locally and still pricey, but of course you don't need much.) Yep, it is the 'spensive, BMW, fuel loving stuff. I don't know how it will get along with Ethanol, but that is another story. Hi Seth...good to see you around these parts. Link to comment
smiller Posted March 28, 2012 Share Posted March 28, 2012 Well I think I'll be OK as long as I let our esteemed panel of environmental scientists handle the climate change debates. Link to comment
Limecreek Posted March 30, 2012 Author Share Posted March 30, 2012 The first electrical check came through without any problems. If you remember I replaced the original main wiring harness with a used one off a very low mileage bike. That and all the repairs to switches, the front loom and the starter left me with a feeling of trepidation as I reached for the ignition. Everything works as it should--ights, starter, interlocks and the dash. We are not about a week away from putting a tank back on the bike and getting her started for the first time in 15 months. Link to comment
roger 04 rt Posted March 30, 2012 Share Posted March 30, 2012 Congratulations to you and son. It seems you've achieved a real milestone. Link to comment
philbytx Posted March 30, 2012 Share Posted March 30, 2012 HERE and HERE are handy dandy articles on submersible FI fuel hose types (30R10 spec). I post info on interior (30R10 spec) and exterior (30R9 spec) FI hoses at least twice a year, I reckon we should have this on a sticky LOL! Link to comment
Limecreek Posted April 6, 2012 Author Share Posted April 6, 2012 Paint should be ready this weekend. I'll assemble and mount the tank and see if she starts up. If all goes well I may be posting a video on Sunday afternoon. Final shots before paint, new windshield and fresh seat. Link to comment
SKYGZR Posted April 6, 2012 Share Posted April 6, 2012 Oil? Don't see any showing in the sight window... Link to comment
Limecreek Posted April 6, 2012 Author Share Posted April 6, 2012 Oil? Don't see any showing in the sight window... Not sure if you are pulling my leg, but yes there is plenty of oil in there. However, it is a fair question if you know the back story to my nick name. Link to comment
roger 04 rt Posted April 6, 2012 Share Posted April 6, 2012 I'm still in awe of your project limecreek. It has led me to repair many minor cosmetic flaws while I'm doing other work. The last touch up was the vinyl glued to the fairing under the seat which had started to peel. How do you recommend polishing the exhausts? Link to comment
Limecreek Posted April 6, 2012 Author Share Posted April 6, 2012 I'm still in awe of your project limecreek. It has led me to repair many minor cosmetic flaws while I'm doing other work. The last touch up was the vinyl glued to the fairing under the seat which had started to peel. How do you recommend polishing the exhausts? The header on the RSL has a silver ceramic coating on it from Jet Hot. They should remain that way for a very long time. On my R12RT I used fine grit dry/wet sand paper followed by polishing compound and a lot of elbow grease. The RT header was stainless and not chrome. Don't use sand paper on a chrome header. I haven't used it, but have heard good things about Rub n Buff for chrome. Link to comment
roger 04 rt Posted April 6, 2012 Share Posted April 6, 2012 On Chrome I've had great results with 0000 steel wool. For the stainless pipes, I've heard that the steel wool can leave residue that oxidizes quickly. I guess that makes sense. It did take the layer of oxidation off initially and doesn't seem to have come back too quickly. Link to comment
Limecreek Posted April 6, 2012 Author Share Posted April 6, 2012 The reflective bag kit arrived and is now on the RSL - thank you Fernando. The seats came back. Just a recover until I decide what I want on there--RDL. The red is dead! I completely forgot about this particular oil head quirk--the center stand in competition with the shifter. And yes, there is oil in there. Link to comment
SKYGZR Posted April 9, 2012 Share Posted April 9, 2012 And yes, there is oil in there. It's bit on the "high" side... Link to comment
Limecreek Posted April 9, 2012 Author Share Posted April 9, 2012 The panels did not come back this week. I did get the tank back yesterday afternoon, but the rest of the pieces will be back late this week. I'll put up a final post in a couple of weeks. It's been a fun project and I appreciate all of the guidance here and through the private messages. Link to comment
Limecreek Posted April 10, 2012 Author Share Posted April 10, 2012 I hit the go button and she fired up. The first thing I found was a leaky quick disconnect. The female side is plastic and must have a crack somewhere--easy fix. The second thing I found was oil leaking out of the left cam chain tensioner; the updated replacement tensioner. I'll have to pull the left TB to have a closer look in the next day or two. Link to comment
eddd Posted April 10, 2012 Share Posted April 10, 2012 I hit the go button and she fired up. The first thing I found was a leaky quick disconnect. The female side is plastic and must have a crack somewhere--easy fix. The second thing I found was oil leaking out of the left cam chain tensioner; the updated replacement tensioner. I'll have to pull the left TB to have a closer look in the next day or two. Was there ever any doubt? Link to comment
Bmr Deacon Posted April 10, 2012 Share Posted April 10, 2012 Congratulations on the fire up. I admire your patience and complete attention to detail. Link to comment
Galactic Greyhound Posted April 12, 2012 Share Posted April 12, 2012 Well done - the bike looks great. The photo record you have provided covering the rebuild will also be of benefit to many others for reference purposes - thank you for taking the time to do this. Link to comment
philbytx Posted April 12, 2012 Share Posted April 12, 2012 BarKeepers Friend works just great on the exhaust Link to comment
Limecreek Posted April 13, 2012 Author Share Posted April 13, 2012 I hit the go button and she fired up. The first thing I found was a leaky quick disconnect. The female side is plastic and must have a crack somewhere--easy fix. The second thing I found was oil leaking out of the left cam chain tensioner; the updated replacement tensioner. I'll have to pull the left TB to have a closer look in the next day or two. Was there ever any doubt? Uh, yes....guess I just got lucky. Link to comment
Limecreek Posted April 13, 2012 Author Share Posted April 13, 2012 Is that dirt on that bolt? I think you are starting to understand my sickness Andy. To be honest, I've looked the other way on several cosmetic items, including the paint. I just have flat out run out of funds. It is funny how one can live with something once the cash pot runs dry. Link to comment
Limecreek Posted April 13, 2012 Author Share Posted April 13, 2012 Well done - the bike looks great. The photo record you have provided covering the rebuild will also be of benefit to many others for reference purposes - thank you for taking the time to do this. Here are a few more photos from the work accomplished last night. Tail Nose Cockpit Link to comment
Galactic Greyhound Posted April 13, 2012 Share Posted April 13, 2012 Beautiful - better than factory Link to comment
Limecreek Posted April 13, 2012 Author Share Posted April 13, 2012 Completed project. I'll put together some before and after shots this weekend. Next on the list: 1. Shake down rides 2. Inspection 3. Cure lean surge 4. Adjust paralever bushing 5. Ride Link to comment
roger 04 rt Posted April 14, 2012 Share Posted April 14, 2012 It's beautiful! I can't believe how good it looks. I was showing my wife the before and after photos. It was hard to convince her that it was the same machine (and she wondered aloud if I'd be attempting a restoration--no). Well done. Looking at your checklist, I'll be interested to see the approach you decide on for curing the lean surge. RB Link to comment
Bruce (Bedford) Posted April 14, 2012 Share Posted April 14, 2012 Awesome! I have really enjoyed watching your progress, I hope you are as fulfilled as you have made us feel - now get out & ride the beast! Thanks so much you are an example to us all, if nothing else then for the picture record. Bruce Link to comment
SKYGZR Posted April 14, 2012 Share Posted April 14, 2012 Needs some accents..pin stripes..perhaps the decals...Gold and Blue would really set it off. Oh yea, gotta take it for a rain ride to "spruce it up a bit" also. Link to comment
ESokoloff Posted April 15, 2012 Share Posted April 15, 2012 Needs some accents...... My thought as well. Pretty freaking awesome otherwise Link to comment
roger 04 rt Posted April 15, 2012 Share Posted April 15, 2012 My red 04 RT came with detailing like that. I made it a condition of sale that it be removed. ;) The white 1100RSL looks perfect as it is. Link to comment
Limecreek Posted April 15, 2012 Author Share Posted April 15, 2012 The newly refreshed RSL got her first taste of bugs, rain and Hill Country roads during a 200 mile ride yesterday and did so without a complaint. The sound and feeling of the single spark boxer and the characteristic handling of the chassis brought back found memories of my '02RT. The bike is nimble, comfortable, (even with the stock seat)fuel efficient and just a hoot to ride. I am very please with how it turned out. Would I do it all over again? Yes. Did I expect to spend what I did? Heck no, but I do not regret it one bit. I hope you had as much fun following along as we did working through the project. That's it. Last post...see you on the road. Before and After Photos Cheers! Link to comment
ltljohn Posted April 15, 2012 Share Posted April 15, 2012 Thanks for sharing all of that it was great to watch it all come together. Link to comment
eddd Posted April 15, 2012 Share Posted April 15, 2012 Very nice. When do we get to see it in person at one of our gatherings? Link to comment
Limecreek Posted April 15, 2012 Author Share Posted April 15, 2012 Very nice. When do we get to see it in person at one of our gatherings? That may be a while. It will be in SLC next month for the WSBK races. My son in law will be on it. No UN for me, nor Torrey this year, but we will return to Silver City/Hannigan Meadows in October and I'll be on it then. Link to comment
BFish Posted April 16, 2012 Share Posted April 16, 2012 congrats on the finished product. it really looks great. it as been my pleasure to drop in on the posts and follow the progress. ride safe. Link to comment
tallman Posted April 16, 2012 Share Posted April 16, 2012 Love the RSL model and you have an outstanding example. Link to comment
TEWKS Posted April 16, 2012 Share Posted April 16, 2012 Nice work! My first BMW BTW. Pat Link to comment
Huzband Posted April 17, 2012 Share Posted April 17, 2012 Beautiful, but needs a picture in a field of Texas Bluebonnets. Good on ya for a fantastic restoration. Hopefully the dogs didn't get out too much. Link to comment
swmckinley Posted April 20, 2012 Share Posted April 20, 2012 Way To Go Greg!!!!!!!!! Not everyone has the tools to accomplish this feat, and I am not talking bout hand tools. The tools I am talking bout are patience, mechanical aptitude, dedication and most important......DOLLARS....Good on ya! Link to comment
ossemon Posted April 2, 2013 Share Posted April 2, 2013 What a simply fantastic project! I wish I was this handy.. Unfortunately, I am not, as evident in my old blog... Link to comment
