Chef Eric Posted December 31, 2010 Share Posted December 31, 2010 02 R1150RT / Why does my clock reset to 00:00? The bike starts up fine. I can't tell if it does it when something goes wrong. It reset once when my fuse went out for my heated grips and it went the same night as when my low beam bulb went out. Or if it is just a coincedence due to another problem. Thanks! Link to comment
ltljohn Posted December 31, 2010 Share Posted December 31, 2010 It is probably because your battery is getting weak and the load of the starter drops the voltage enough to reset the clock. You could also have loose/corroded connections on the battery or the starter. Link to comment
boatzo Posted December 31, 2010 Share Posted December 31, 2010 I agree with Ltljohn. Do your ABS lights flash alternately as well? That would definatly indicate battery or connector problems. If the lights are not showing a fault , then there is another circuit problem affecting the clock. Almost sounds like a wiring gremlin with those multiple problems Link to comment
kmac Posted January 1, 2011 Share Posted January 1, 2011 How far apart did the fuse blow, the bulb blow, and the most recent clock reset happen? If these events have all happened in quick succession, you may have a bigger problem, like a short circuit or a ground issue. It could of course be a battery that has a dead cell. It may show 12-14 volts on a simple volt meter, but when under load it drops voltage causing any or ALL of your electrical woes. Bottom line is, the clock resets whenever voltage is interupted. Find the interuption, find the clock problem. Link to comment
dan cata Posted January 1, 2011 Share Posted January 1, 2011 A weak battery or a bad connection to one of it's leads. I had it on my GS, it was indicating for how long I was riding and not the actual time And it was also stopping every now and then, once during an overcome. Dan Link to comment
Chef Eric Posted January 1, 2011 Author Share Posted January 1, 2011 Thanks for the info. Link to comment
kmac Posted January 1, 2011 Share Posted January 1, 2011 Morning Chef, When I first got my R1100RT it had sat for a while. I was having the clock reset and the ABS light tripping issues that are so common. I was ready to buy a new battery even though the one in my bike looked pretty new and was fully charged. While I had the tupperware off for my first valve adjustment, I completely cleaned my battery terminals and each one of the wire eyelets with some sand paper because they looked a bit oxidized. Whallah no more problems with anything electrical since then. Its a cheap first step that may solve your issues or at least eliminate one. Link to comment
flars Posted January 2, 2011 Share Posted January 2, 2011 What everyone else said about connections, starter drag, etc. Also, starting the bike the first time in the morning during cold weather will make my RS clock reset. Link to comment
Chef Eric Posted January 2, 2011 Author Share Posted January 2, 2011 It has only happened when it has been cold here. I will clean up the battery and see if that helps. Link to comment
oldyam Posted January 2, 2011 Share Posted January 2, 2011 Might also be worth dropping down to 5W40 or 30 engine oil if its only a cold weather thing as 20W50's is pretty heavy in cold weather adding a lot of starting load. Link to comment
Peter Parts Posted January 3, 2011 Share Posted January 3, 2011 Might also be worth dropping down to 5W40 or 30 engine oil if its only a cold weather thing as 20W50's is pretty heavy in cold weather adding a lot of starting load. Better to move to 15-50 or I think I saw 0-50 synthetic. 20-50 synthetic is just fine in the winter around here. Ben Link to comment
kmac Posted January 4, 2011 Share Posted January 4, 2011 OH NOOOOOOO ANOTHER OIL DISCUSSION eVERYBODY RUNNNNN... Link to comment
NonComp Posted January 4, 2011 Share Posted January 4, 2011 02 R1150RT / Why does my clock reset to 00:00? The bike starts up fine. I can't tell if it does it when something goes wrong. It reset once when my fuse went out for my heated grips and it went the same night as when my low beam bulb went out. Or if it is just a coincedence due to another problem.Different motorcycle, but on my ST1300, this is the first sign that the battery is on its way out. The reset occurs during cranking when the voltage drops low enough to cause the display to reset, even though the bike still starts OK. Link to comment
