David Posted December 22, 2010 Share Posted December 22, 2010 Took two months to ship from Austria, but here it is. The machine as a whole: Extension table (very robust), useable on any of three sides: Solid acryclic wheel with solid steel axle: Blade tightness gauge as viewed through open window. It's a starting place, based on width of the blade. This was a 1" blade, so you can see where I set it: Lower roller with dust control brush and yellow foot brake: Upper roller, along with tension gauge on lower left. See safety red box in upper right that keeps machine from starting unless large door is closed: Upper European style roller guides, side to side and front to back. This whole arm goes up and down based on the height of the cutting piece: Ditto Lower European style roller guides, side to side and front to back: Fence (usable on three sides). Very robust: Foot brake and front wheel assembly to move it around (just under 1,000 lbs): Wheels to adjust wheel tracking and wheel tension: Link to comment
Joe Frickin' Friday Posted December 22, 2010 Share Posted December 22, 2010 OK, I'm drooling. Looks like a nice tool. For wood only, or are you going to start doing metal work? Link to comment
WURTY Posted December 22, 2010 Share Posted December 22, 2010 David looking good. Nice choice Link to comment
David Posted December 22, 2010 Author Share Posted December 22, 2010 OK, I'm drooling. Looks like a nice tool. For wood only, or are you going to start doing metal work? With the right blade, it'll cut darn near anything. It's 220, 20 amp, single phase with huge flywheels. So not much will stop it. Link to comment
Bud Posted December 22, 2010 Share Posted December 22, 2010 Wow, you win the prize for the neatest tool in the shop. I'm jealous. Congrats Link to comment
LJR Posted December 22, 2010 Share Posted December 22, 2010 Awesome! you must have a project in mind for it... Link to comment
enfoman Posted December 23, 2010 Share Posted December 23, 2010 OK, I'm drooling. Looks like a nice tool. For wood only, or are you going to start doing metal work? With the right blade, it'll cut darn near anything. It's 220, 20 amp, single phase with huge flywheels. So not much will stop it. +1 on that. No Problem! Link to comment
Jerry Johnston Posted December 23, 2010 Share Posted December 23, 2010 They sure have improved them over the years. I have a Rockwell that has a 12" depth cut but is so... much more work to make changes than the newer units. I'm envious of yours but happy for ya ! Looks like you'll have a really merry Christmas. Link to comment
EddyQ Posted December 23, 2010 Share Posted December 23, 2010 Very nice ! I have an 16" grizzly. At the time of purchace, I didn't think I'd use so much. I regret buying a better saw. Resawing, sawing really thick boards is a great capability. Your saw looks like a winner ! Ed - Link to comment
EddyQ Posted December 23, 2010 Share Posted December 23, 2010 OK, I'm drooling. Looks like a nice tool. For wood only, or are you going to start doing metal work? With the right blade, it'll cut darn near anything. It's 220, 20 amp, single phase with huge flywheels. So not much will stop it. After wiring 220, you may want to convert all your tools with greater than 1HP. I did and am very glad I did. Link to comment
David Posted December 23, 2010 Author Share Posted December 23, 2010 Yes, you're right. I have a SawStop 1.75 Professional Contractor Saw that's 110. I just ordered a kit that'll turn it into 220. It won't necessarily be more powerful, but it'll step up faster and will run cooler. Link to comment
