IKIMURA Posted December 18, 2010 Share Posted December 18, 2010 Anyone able to tell me were I can find the oil filter on a 2001 1100RT. Link to comment
Boffin Posted December 18, 2010 Share Posted December 18, 2010 Under the motor in a recess. You will need a wrench to remove it. If you take your new filter along to an auto supply shop you will be able to find one that fits, or you can buy one for more money from your dealer. Andy Link to comment
NonComp Posted December 18, 2010 Share Posted December 18, 2010 It's recessed in a well on the bottom of the engine, left-hand side. You usually need a special wrench to remove it. BMW filters have a different knurling pattern on the end than other name-brand filters, so after-market end-cap wrenches may not work. Link to comment
IKIMURA Posted December 18, 2010 Author Share Posted December 18, 2010 Wow thanks that was a fast response! Anything else I should do while the side panels are off? I will be installing the relay setup for the lights. Link to comment
Paul Mihalka Posted December 18, 2010 Share Posted December 18, 2010 Purolator L10241 filters have the same wrench pattern as the original BMW filter, and are a common low cost non-BMW replacement. Link to comment
AndyS Posted December 18, 2010 Share Posted December 18, 2010 Wow thanks that was a fast response! Anything else I should do while the side panels are off? I will be installing the relay setup for the lights. OIl Change Transmission oil change FD oil change Alternator belt check Chop alternator cover in half horizontaly for easier access in the future. Valve adjustment Throttle body clean Throttle body balance Fuel filter change. Check you have all the spares prior to ripping stuff apart. Andy Link to comment
