leeinmemphis Posted December 17, 2010 Share Posted December 17, 2010 Hey everyone, I have a Garmin zumo 550 that I would like to mount on the RT. I would like to mount it up behind the windshield but was wondering if there are any options to do that other than buying the shelf and base mount for the shelf? I was hoping that I could get away with something a little less expensive because I didn't want to spend ~$200 for the shelf/base. I already have a standard Garmin handlebar mount but would much prefer it to be in front of me in my field of vision. If it comes down to it I'll buy the shelf/base mount but was hoping there may be a more economical solution. Any advice or suggestions would be appreciated. Thanks Link to comment
dan cata Posted December 17, 2010 Share Posted December 17, 2010 I use a vacuum mount, like in cars. I installed it over the speedometer glass, since the gps also indicates speed Dan. Link to comment
oldyam Posted December 17, 2010 Share Posted December 17, 2010 How about something like this :- http://www.motorcycleparts-hornig.com/BMW-R-1100-1150-RT/Navigation-and-Communication/GPS-Mounts.html I have this on the 1100RT but they do a version for the 1150RT too with the Zumo. Its strong and neat worked well this summer touring germany Can be adjusted to be able to see clocks and clear screen in the lowest position. Link to comment
dirtrider Posted December 17, 2010 Share Posted December 17, 2010 Evening leeinmemphis Might take a look that this link (click link). A nice simple center mounting of a Zumo 550. 1150RT_GPS mounting Link to comment
mike g Posted December 17, 2010 Share Posted December 17, 2010 I use this one mounted to one of the handlebar mounting bolts. Have used it for 5 years now and no problems. I have a spare one for my other bike and switch the gps. http://www.ram-mount.com/CatalogResults/PartDetails/tabid/63/partid/082065077045066045050053050085/Default.aspx mike Link to comment
APDDave Posted December 17, 2010 Share Posted December 17, 2010 It might be a little more than you want to spend, but I used the mount from Gadget Guy that puts the GPS up above the gages and it is rock solid and a very quality mount. http://www.gadgetguy.net/PhotoGallery/BMW_07_R1150RT_KitIVsolo_BasePlateII_SPIII/BMWR1150RT_KitIVsolo_BasePlateII_SPIII.html Link to comment
AndyS Posted December 17, 2010 Share Posted December 17, 2010 Any advice or suggestions would be appreciated. Thanks What Bike are you talking about? Simon has recently fitted one of these http://www.motorcycleparts-hornig.com/BM...GPS-Mounts.html to his R1100RT and he says it works well. It is very simple to mount and comes with the mounting block to han the GPS on. It is stainless steel, but would blend in nicer (IMO) if it were satin black. The R1150RT would find it even more solid, because the fairing is a little better supported internally. The reason I quite like this unit is because it puts it up fairly near the sight line and so the rider does not have to look down for long. Also depending on where it is mounted along the bar (you can position it anywhere along it), you can choose the best visibility for you. Andy Link to comment
94aero Posted December 17, 2010 Share Posted December 17, 2010 What's a GPS?? Geezer Positioning System! Link to comment
dirtrider Posted December 17, 2010 Share Posted December 17, 2010 What's a GPS?? Morning Skygzr That is an acronym for-- “(G)reat (P)lace to (S)top” to look at your map. Link to comment
Rex R Posted December 17, 2010 Share Posted December 17, 2010 I had the same question about 6 months ago and came up with pretty much the same answers. But another option you can consider is the RAM resevoir cover mounts. part #s 345 and 346. They put the gps higher than mounting it to the handlebar bolts (although to the right or left of center depending on if you mount it to the front brake or clutch resevoir). But with a longer mounting arm, you can shift it towards the center of the bike. I considered using it for my Garmin Quest, which is very light. So I never considered the weight at the end of a long mounting arm a (potential) problem. I don't know if it might become a problem for the Zumo. Good luck. Post some pictures after you're done. Link to comment
BFish Posted December 17, 2010 Share Posted December 17, 2010 I had the same question about 6 months ago and came up with pretty much the same answers. But another option you can consider is the RAM resevoir cover mounts. part #s 345 and 346. They put the gps higher than mounting it to the handlebar bolts (although to the right or left of center depending on if you mount it to the front brake or clutch resevoir). But with a longer mounting arm, you can shift it towards the center of the bike. I considered using it for my Garmin Quest, which is very light. So I never considered the weight at the end of a long mounting arm a (potential) problem. I don't know if it might become a problem for the Zumo. Good luck. Post some pictures after you're done. it's not an issue for my 2610 antique gps. Link to comment
cali_beemer Posted December 17, 2010 Share Posted December 17, 2010 I just ordered the BMW GPS mount but its designed for the BMW shelf. My bike came with the shelf so it was a minimal investment to buy the bracket. I do like that the shef and bracket put the GPS up high and alot closer to the rider for easy access while riding. I will be doing a full install this weekend. One nice thing about the shelf is that there is a place for the XM antenna and a radar detector if I like. Link to comment
SKYGZR Posted December 18, 2010 Share Posted December 18, 2010 That is an acronym for-- “(G)reat (P)lace to (S)top” to look at your map. Good One kinda like (G)otta(P)ee(S)top Link to comment
leeinmemphis Posted December 18, 2010 Author Share Posted December 18, 2010 well I ordered the BMR shelf today with the base for a zumo. A gps is important to me when I ride and figured it was probably worth the $$$ to get it. I should get it sometime next week. Hopefully I'll be able to get it installed the week between Christmas and New Years. Link to comment
Mark K Posted December 19, 2010 Share Posted December 19, 2010 Excellent choice. You'll find uses for the extra room! Link to comment
cali_beemer Posted December 19, 2010 Share Posted December 19, 2010 My BMR GPS bracket just showed up so i can now add it to the BMR shelf. It all seems like high quality stuff. I like having a place for my GXM antenna. Link to comment
Schooly Posted January 1, 2011 Share Posted January 1, 2011 If I could jump in here with a question about the shelf... I have heard that they tend to flex a lot and cause the GPS to bounce around. Has anyone had this problem and if so were you able to fix it? Link to comment
Starfighter Posted January 1, 2011 Share Posted January 1, 2011 I have a BMR shelf on the K-bike with a touratech bracket for my GPS....rock solid and my favorite mount. On the RTP, I fashoned a shelf from 1/4" plexi and used a standard GPS bracket. Took some adjusting but flexd is pretty minor. The secret seems to be long brackets reachi8ng down onto the dash. Link to comment
cali_beemer Posted January 1, 2011 Share Posted January 1, 2011 The BMW shelf is rock solid. No flexing. I just used mine for a 2 day trip and no problems. It worked great. Here are a few crappy camera phone pictures of it with the BMW GPS mount. Link to comment
kmac Posted January 1, 2011 Share Posted January 1, 2011 EEK GADS does that thing show movies? TV? Do people park behind you and watch it like a drive-in theater? Link to comment
