ChuckAZ Posted December 15, 2010 Share Posted December 15, 2010 This is a new to me RT. When I push the bike into the garage and turn the bars Ihear the calipers/pads pretty bad on the rotors it is louder in reverse for some reason and when the bars are straight there is no dragging at all. I have replaced the pads with hawk HH pads recently but did not really ride or move the bike before those were installed so I have no comparison. Link to comment
dan cata Posted December 15, 2010 Share Posted December 15, 2010 Put the bike on the centerstand and rotate the front wheel by hand. Does it spin easily? Some drag is normal, it's suppose to turn like 2 more revs after letting it go. Two winters ago I changed the brake hoses on my GS. I was riding it during winter on salty roads. The L/H/S caliper pistons were stuck! On the R/H side only one piston was moving. Since I had them off, I pressed the pistons using a large wrench and it got un-stuck. Then I sprayed plenty of brake spray in there and it went back to normal Dan. Link to comment
Jerry Duke Posted December 15, 2010 Share Posted December 15, 2010 +1 for Dan's fix. I spray the calipers liberally with brake cleaner and work the pistons every time I change the pads. Link to comment
ChuckAZ Posted December 16, 2010 Author Share Posted December 16, 2010 Thanks guys I will check it out this weekend. Link to comment
John Dickens Posted December 16, 2010 Share Posted December 16, 2010 Like Dan and Jerry I use brake cleaner and a toothbrush to clean the pistons whenever I change the pads. A smear of silicone grease doesn't go amiss either. Link to comment
kmac Posted December 16, 2010 Share Posted December 16, 2010 You can also use a brake rated grease on the pins that hold the pads in and the caliper retaining bolts or pins so that the calipers are freely moving. Link to comment
Goomicoo Posted December 17, 2010 Share Posted December 17, 2010 You PUSH your bike into the garage My driveway is uphill, I wish I could push the bike in. It's the last adventure after a ride for me. Garage open: check Path clear : check Pets secure: check Tallyho Link to comment
Shuffler Posted December 17, 2010 Share Posted December 17, 2010 Mine does that too. I don't see any issue...my pads are good, the brakes work very well. I rack it up to the floating discs being just loose enough to rub on the pads when the wheel is leaned over one way or the other. Link to comment
