Unhofliche_Gesundheit Posted November 23, 2010 Share Posted November 23, 2010 Anyone else having problems with their Tourmaster zipper 'pull tabs' breaking off? What did you do to fix it? My tourmaster 'transition 2' jacket, 'Solution' boots, and 'Venture air' pants were bought in August 2008 - so clearly no longer under warranty (their web site says 1 year) - so sending them back for repair is not an option. i like the gear but today the zipper pull broke on one of the boots (nice ride btw. & mine was the only bike i saw in 250 km...) . The zipper pull on the jacket broke about a month ago. i am not particularly rough on my stuff i have lots of jackets which are several decades old with no zipper problems - so this short lifespan is not impressive to say the least. thank goodness the zippers still work (the zipper slides are still in place) but not very well as very hard to get a grip on the slider. the boot zipper is particularly annoying to get to move. i was thinking a small tie wrap threw the hole in the slide but maybe someone has a better idea? thanks. Link to comment
Redbrick Posted November 23, 2010 Share Posted November 23, 2010 Yep........Tour Master overpants zipper pull broke off and one on my BMW Jacket too.......I put one of these expensive little things on each and they work fine.... http://www.aerostich.com/aerostich-zipper-pull-strips.html Link to comment
Paul Mihalka Posted November 23, 2010 Share Posted November 23, 2010 I had a zipper tab break on something. I fixed it with a larger type paper clip. Not elegant, but it worked. Link to comment
kmac Posted November 23, 2010 Share Posted November 23, 2010 Did the entire metal piece of the tab break off or just the plastic/fabric extender? If it is just the extender then redbricks link will work but if it is the metal piece that hooks to the zipper base mechanism, the you could use a small piece of wire to make a loop, and then add the tabs in redbricks link. You might try using a small round ring from a bracelet, not gold or silver since they are soft, but maybe surgical stainless steel. Like you might find at a kiosk in a mall or in the costume jewelery area in the womens dept. Link to comment
Selden Posted November 24, 2010 Share Posted November 24, 2010 The zipper pull tab on my Tourmaster jacket snapped off right where the plastic meets the metal about 2 months ago; I improvised a new pull tab from an old piece of plastic and a small split ring. I thought it was a fluke, but it sounds like this is a not uncommon problem. I suspect that a tailor/alterations shop could fit a proper new pull tab. Link to comment
drswift Posted November 24, 2010 Share Posted November 24, 2010 If you want a perfect match, find out who does their warranty repairs (one such place is Rainy Pass Repair, in Seattle, WA) and see if they will send you a replacement zipper. Any good alterations place can swap out the pull tab mechanism). Link to comment
Unhofliche_Gesundheit Posted November 24, 2010 Author Share Posted November 24, 2010 wow 5 replies - good ones too! thanks - the paper clip and split rings are both excellent ideas - they are free & i have large quantities of both - nice to find a use for them. hope the sliders dont break next. ---- Reissverscheisse odor Reissverschluss? Link to comment
skinny_tom (aka boney) Posted November 24, 2010 Share Posted November 24, 2010 It's not just limited to Tourmaster. I use split rings too, then add a pull tab. Link to comment
cruisin Posted November 24, 2010 Share Posted November 24, 2010 the wire used in spinnerbaits is very strong stanless steel and can be obtained in any Wal Mart's fishing tackle area for very low cost if you buy a multipack of spinnerbaits. Like a couple others said, "not elegant but effective." Before making your tab from a spiinerbait though, just be sure to cut away and the lead head and hook for your own safety and dignity. Link to comment
elkroeger Posted November 24, 2010 Share Posted November 24, 2010 +1 on Rainy Pass Any good alteration shop, or perhaps even a cobbler, could do the job, good as new. Lately I just use some 1/8" nylon twine. Tie a 1" loop into the slider. I've done the paper clip fix. Once I got industrious and soldered the paperclip together after installing it. Looked a wee goofy, but worked like it had never been broken! Link to comment
Deek Posted November 24, 2010 Share Posted November 24, 2010 "...i was thinking a small tie wrap threw the hole in the slide but maybe someone has a better idea?...." I insert large paperclips to replace the pulls, then put duct tape on the clip. Works well, but not too pretty. Link to comment
kmac Posted November 25, 2010 Share Posted November 25, 2010 The hole in most zipper bases is pretty small. Not sure if a zip tie will fit, i do have some pretty small Zip ties tho. Split rings and any kida tab. Link to comment
woodnfly Posted November 26, 2010 Share Posted November 26, 2010 ive used the snap swivels from my tackel box on zippers,the barrel swivel part also helps in haveing something to grab onto Link to comment
Jerry Johnston Posted November 26, 2010 Share Posted November 26, 2010 If you goggle "zipper repair" or "zipper pull" you'll find there are lots of place to buy from. Link to comment
Rinkydink Posted December 2, 2010 Share Posted December 2, 2010 I use zip ties and they work great! Link to comment
