Tucker2930 Posted October 24, 2005 Share Posted October 24, 2005 Any changes from 2005 to 2006? Link to comment
dwayrider Posted October 24, 2005 Share Posted October 24, 2005 Yes. They are minor. To engage the emergency signals, you press simultaneously on the left and right turn signal buttons. There is no round red button for that purpose any more. The ambient temperature on the '06's Bordcomputer is accurate. On the '05 it read from 5° to 10° degrees too cold. The pricing is pretty much a la carte in order to lower the base MSRP. For example, heated grips and cruise control are no longer standard, but are options. I think the license plate bracket is still standard There may be other changes I am not aware of, but they would also be pretty minor. Link to comment
codinn Posted October 24, 2005 Share Posted October 24, 2005 The ambient temperature on the '06's Bordcomputer is accurate. On the '05 it read from 5° to 10° degrees too cold. So is this an admission that the '05 ambient temperature reading is flawed and eligible for repair as a warranty item? I am not holding out any hope for the oil level sensor <!> but it would be nice if the temp gauge worked. Link to comment
Pickaxe Posted October 24, 2005 Share Posted October 24, 2005 Yes. The ambient temperature on the '06's Bordcomputer is accurate. On the '05 it read from 5° to 10° degrees too cold. Surely it's just the sensor thats inaccurate or could it be more complicated? Link to comment
BitScribbler Posted October 25, 2005 Share Posted October 25, 2005 I believe they've also improved the contrast/legibility on the LCD displays. This is true for all the hexheads I assume. Link to comment
