Bakaboy Posted June 12, 2010 Share Posted June 12, 2010 First time to change the battery in the F650CS. How do I access it to get it out? Link to comment
elkroeger Posted June 12, 2010 Share Posted June 12, 2010 My Haynes manual just says remove left front side panel, then basically reach in there and pull it out. I don't remember it being that easy. That battery is tucked down in there tight. My memory is a little hazy, but you may need to remove both front side panels, and loosen the metal frame that supports that bird bath. For each side panel: remove the "side handles", two screws (four total) at the rear of the panel, one screw at each forward and rear bottom corner. There's a trim piece at the front of the bird bath (on top) which needs to be unscrewed. Front turn signals too. I just (carefully) let the side panels dangle from the turn signal wires instead of disconnecting all of that. I recall that the metal support frame has 4 legs, undo the rear, and just loosen the front so the whole thing can tilt up just a bit. You might be able to skip this step. I have a vague recollection of loosening the fuseblock to slide it sideways a little. Once you're in there, remove the cables, then pull it out. I recall using a 1/4" drive socket (10mm perhaps) on a 12" extension. Thread that in from the right side of the bike to undo the screw at the forward terminal. I believe the forward terminal is positive, so make certain you disconnect the negative first. I looked into upgrading the battery from the OEM, but there was only one (might've been an Odyssey) that would fit. And even then, it didn't really fit anyway - to squeeze it in there, you have to remove the battery tray and trim it significantly. After getting the original battery out, and looking at what's required, I determined that it's a whole lot easier to just put in the OEM unit. Good luck. You should find more info here: http://www.f650.com/ Link to comment
