Dan McClure Posted June 6, 2010 Share Posted June 6, 2010 I installed a Centech fuse block and run/flash Hyper-lites on my 2010 RT. I first connected the switched power wire to the rear accessory socket. This worked but, the lites remained on after turning the bike off for some time. Apparently the power socket continues to get power after shut down if it's needed. So after searching the forum I found some have connected to the black/yellow wire on the starter relay, I think that's what it is. So I connect to it, turn ignition key on, Lites work as advertised Try to start bike and all I get is a loud clicking sound like the starter won't in-gauge Any ideas????? Link to comment
tallman Posted June 6, 2010 Share Posted June 6, 2010 Start by discaonnecting, running power for fuse block directly to battery. Yes, I know others don't do that, but I've seen problems doing it thru the stock wiring and none going directly to battery. Does your bike have an alarm? Link to comment
Dan McClure Posted June 6, 2010 Author Share Posted June 6, 2010 I disconnected the battery for about 5 minutes and the switched power lead is not connected. No start. There's not an alarm, chip'd keys. Link to comment
Indy Dave Posted June 6, 2010 Share Posted June 6, 2010 Dan, If I'm reading your last post correctly, the fuse block is now disconnected and you still have problems with the starter engaging? Is it possible your battery is low and needs charging? Do you have a charger or voltage meter you can check the battery with? Link to comment
Dan McClure Posted June 6, 2010 Author Share Posted June 6, 2010 Plugged into the charger. I'll see what happens. Link to comment
Dan McClure Posted June 7, 2010 Author Share Posted June 7, 2010 Someone come take all my tools away. I obviously have no mechanical skills. Battery charged, bike starts, lites work, switched wire installed. My wife told me to charge the battery.......ignored her Link to comment
Indy Dave Posted June 7, 2010 Share Posted June 7, 2010 glad all's well ~ enjoy the ride! Link to comment
