Graeham White Posted June 6, 2010 Share Posted June 6, 2010 I have checked the switch and it appears to be working, yet the grips are always hot? Is there a relay that could be stuck in "on" position? Link to comment
4wheeldog Posted June 6, 2010 Share Posted June 6, 2010 I just looked this up in my handy dandy Elektriska Kopplingsscheman(Electrical circuit diagrams). There is only a switch immediately upstream of the grips themselves. I would think that the malfunction has to be in the switch, since it is downstream of everything else. If you have gotten the bike very, very wet, you might try a hair dryer on the switch. Otherwise, some disassembly may be required. Good Luck. Link to comment
Graeham White Posted June 6, 2010 Author Share Posted June 6, 2010 Thanks will check switch action again. Link to comment
SikDMAX Posted June 7, 2010 Share Posted June 7, 2010 I believe I know, but the switch is Up/Center/Down High/Off/Low, correct? Link to comment
jfremder Posted June 8, 2010 Share Posted June 8, 2010 Pushing the top of the switch has the grips off The Center is Low Pushing the bottom is High Link to comment
Secret Buzzard Posted June 9, 2010 Share Posted June 9, 2010 I notice you have an RT-P. They use one of the auxiliary switches in the add-on boxes to operate the heated grips. The switch on the right grip assembly that works the grips on the civilian models is used for some of the police lighting. I easily re-wired mine to work with the original switch. Just something to check. Link to comment
SikDMAX Posted June 9, 2010 Share Posted June 9, 2010 Add on boxes? My heated grip switch is on the left side dash, next to the ABS switch. I swore up was high, center off and down low. Ill check tonite, goin for a ride. Link to comment
tdshepard Posted June 10, 2010 Share Posted June 10, 2010 My heated grip switch is on the left side dash, next to the ABS switch. I swore up was high, center off and down low. On my 1998 RT-P that is correct. Link to comment
Secret Buzzard Posted June 10, 2010 Share Posted June 10, 2010 An 1150 should have the heated grip switch on the right hand grip assembly. The authorities version used that switch for some of the lights and moved the grip heater to one of the add-on switch boxes. It can easily be changed back if you aren't using the add-on switches. The 1100RT was: Up-high center-off down-low. The 1150 was: up-off center-low down-high. Link to comment
SikDMAX Posted June 10, 2010 Share Posted June 10, 2010 Pictured and circled here on my 1100RTP. And yes, thats 11k miles Link to comment
GMC Posted November 13, 2011 Share Posted November 13, 2011 My 03 RT-P has switch on left grip. Up=high, center=off, down=low. Link to comment
dan cata Posted November 13, 2011 Share Posted November 13, 2011 Pictured and circled here on my 1100RTP. And yes, thats 11k miles It looks so good. I like it! Dan. Link to comment
AndyS Posted November 14, 2011 Share Posted November 14, 2011 My 03 RT-P has switch on left grip. Up=high, center=off, down=low. Are you sure it is the left grip? Most 1150's are on the right hand switch cluster. And as if you didn't know, I am talking about the civilian bike. Also the switching arrangement is: top pushed in - off mid position - medium heat bottom pushed in - max heat. Link to comment
AndyS Posted November 14, 2011 Share Posted November 14, 2011 Pictured and circled here on my 1100RTP. But the OP is talking if the 1150 which is a different beast. Andy Link to comment
