crmdgn Posted June 3, 2010 Share Posted June 3, 2010 Trying to take off the tail light lens tom see if nI have the Kisan nbulb for brake flashing. Does it pry off, do I take out the 3 - 5 screws(seem to hold some of the lower rear fairing), or drill a hole in the lens(lol) My manual is not clear, at least to me. thNKS paul Link to comment
Heyfrank Posted June 3, 2010 Share Posted June 3, 2010 I believe there is 2 thumb screws on the back tail section under the seat. Link to comment
BevBeng Posted June 3, 2010 Share Posted June 3, 2010 No drilling required. Remove the passenger seat. There are 2 larger plastic ring nuts under the tail section that hold the tail light assembly in. Link to comment
Boffin Posted June 3, 2010 Share Posted June 3, 2010 No drilling required. Remove the passenger seat. There are 2 larger plastic ring nuts under the tail section that hold the tail light assembly in. If these are too tight to turn by hand a 19mm socket (the same as the rear wheel) fits them nicely. Andy Link to comment
crmdgn Posted June 3, 2010 Author Share Posted June 3, 2010 Thanks all, I found the two hand screws, just a minute ago. Easy to remove and see the offending brake/tail light(flashing at will, and braking with no discernible pattern) Bulb says www.gizmomi11.com(I thinnk)and no combination I can find yet, sheds any light so back to research. Again thanks paul Link to comment
Sidmariner Posted June 4, 2010 Share Posted June 4, 2010 If you have a Gizmo-Mill bulb then you have the "BRAKE" light and not the KISAN light. Gizmo Mill became Road Rocketeer and went out of business last year. They had two available bulb modules, the upper one provided the flashing strobe effect and the lower one provided a bright running light, with a downward beam to illuminate the licence plate. See my post: http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Main=24585&Number=258368#Post258368 I have the BRAKE lights and like them. I was sorry to see the company fold. Link to comment
