BarOne Posted June 1, 2010 Share Posted June 1, 2010 What is the particular tool for removing the front wheel of an RT (05) and where can I find one? Link to comment
onmyrt Posted June 1, 2010 Share Posted June 1, 2010 I use one of these spark plug sockets: Just invert the socket, using the nut end, and it works great. Link to comment
Rinkydink Posted June 1, 2010 Share Posted June 1, 2010 Cycle Gear sells a multi-tool for about $20 I think... Link to comment
Paul Mihalka Posted June 1, 2010 Share Posted June 1, 2010 Ebay for about $16.50 shipped: http://cgi.ebay.com/ebaymotors/BMW-R1200GS-F800GS-Front-Wheel-Nut-Tool-Made-USA-_W0QQcmdZViewItemQQhashZitem563c74a2d4QQitemZ370381464276QQptZMotorcyclesQ5fPartsQ5fAccessories Link to comment
pmurphy Posted June 1, 2010 Share Posted June 1, 2010 Motion Pro also makes one: http://www.motionpro.com/motorcycle/tools/category/axle/ Link to comment
hopz Posted June 1, 2010 Share Posted June 1, 2010 Just invert the socket, using the nut end, and it works great. I may be off base, but I think what he means is for you to find a large nut and insert it partially into the Axle hole and use the spark plug socket over the part that is not in the hole... Link to comment
motoguy128 Posted June 1, 2010 Share Posted June 1, 2010 Just invert the socket, using the nut end, and it works great. I may be off base, but I think what he means is for you to find a large nut and insert it partially into the Axle hole and use the spark plug socket over the part that is not in the hole... No, I think he means that you take that spark plug socket and using an extension, install the socket backwards on the extension and insert the hexagonal end into the axle. Presto, you have a very large hex tool... and a spark plug wrench as well. The really cheap, thin steel galvanized spark plug tools work well too. That's what I use. Link to comment
BarOne Posted June 1, 2010 Author Share Posted June 1, 2010 Thanks folks -- what a great bunch! Link to comment
Anton Largiader Posted June 1, 2010 Share Posted June 1, 2010 The really cheap, thin steel galvanized spark plug tools work well too. That's what I use. If you're talking about the K-bike spark plug wrench, it works wonderfully. The outside of the spark plug wrench is a perfect fit in the axle and you can put a 17mm socket on the other end. As for cheap, well it may not be expensive (?) in fact it's free when you have this sort of stuff lying around, but I wouldn't insinuate that it's flimsy. Link to comment
alimar Posted June 1, 2010 Share Posted June 1, 2010 For $25 shipped Marc Parnes makes one too. Marc Parnes Axle Tool check the wheel balancer too. I like it. Link to comment
onmyrt Posted June 1, 2010 Share Posted June 1, 2010 Just invert the socket, using the nut end, and it works great. I may be off base, but I think what he means is for you to find a large nut and insert it partially into the Axle hole and use the spark plug socket over the part that is not in the hole... No, I think he means that you take that spark plug socket and using an extension, install the socket backwards on the extension and insert the hexagonal end into the axle. Presto, you have a very large hex tool... and a spark plug wrench as well. The really cheap, thin steel galvanized spark plug tools work well too. That's what I use. Bingo (sorry for not explaining it well enough) Link to comment
BarOne Posted June 1, 2010 Author Share Posted June 1, 2010 The Marc Parnes tool is the bees knees -- versatile and reasonably priced! Thanks Alimar and the rest of you inmates! Link to comment
