BRT Rider Posted May 27, 2010 Share Posted May 27, 2010 I recently mounted the Suburban peg lowering kit on my 2007 K1200GT. I was able to adjust the shifter in a comfortable position, but I can't figure out how to adjust the rear brake pedal. Is there an adjustment? Link to comment
eaglemike Posted May 27, 2010 Share Posted May 27, 2010 Not an easy way (that I can see) at this time. I'm looking at a couple of different ways. One is to adjust the linkage and then add a stop to keep the pedal down. Another is to make an offset extension. One could cut and weld the part. Or make a different lever. I'll be experimenting with the adjustment and stop thing this weekend. If you have another idea please let me know. (I own a machine shop) all the best, Mike Link to comment
Rphoto Posted May 27, 2010 Share Posted May 27, 2010 Pirateslair sells a cap that makes your brake pedal larger. Works very well. Link to comment
BRT Rider Posted June 3, 2010 Author Share Posted June 3, 2010 The cap to enlarge the brake pedal could be helpful, but the real issue is lowering the pedal. Link to comment
