David Posted May 25, 2010 Share Posted May 25, 2010 This was fun, particularly since I made it all from scraps I had lying around: Process was: Square off the sides of each piece with a bench saw. Make each piece a uniform width, also with a bench saw. Use a thickness planer to get all the strips to a uniform thickness, matching the thinnest one (they were different widths and thicknesses). Glue and clamp. Cut the shape out with a jig saw. Use a rounding over bit on a router to shape the edge (it's on the reverse side of this) Drill 1/2" holes for the 1 1/2" walnut plugs. These hold the cutting board in exactly a position to cover the lefthand sink, where the disposal is mounted. The cutout is meant to make it easy to shift the scraps over with your knife and dump them in the disposal side. Soak everything in walnut oil, which is safe for food preparation. Bake in the sun, where this picture was taken, to harden the oil surface. UV rays do the trick for that. It's a terribly inefficient process, but I enjoy the mental discipline that woodworking requires. And Julie likes her custom cutting board! Link to comment
1MPH Posted May 25, 2010 Share Posted May 25, 2010 Nice looking cutting board. Good job. Link to comment
tallman Posted May 25, 2010 Share Posted May 25, 2010 I thought it was a closeup of a custom sidestand support for soft ground. Nice. Link to comment
BFish Posted May 25, 2010 Share Posted May 25, 2010 very, very nice....will you squirm the first time it serves it purpose? Link to comment
David Posted May 25, 2010 Author Share Posted May 25, 2010 No squirming for me. It'll hide the mistakes I made. Link to comment
BFish Posted May 25, 2010 Share Posted May 25, 2010 is the cut-out side slightly lower than the other? may keep stuff from running off onto the counter. ps...really wanted to put " " around stuff, but suppressed the urge. Link to comment
David Posted May 25, 2010 Author Share Posted May 25, 2010 If it's lower, it's just a mistake. I may still add some channels toward the edges. Link to comment
Joe Frickin' Friday Posted May 25, 2010 Share Posted May 25, 2010 It's a terribly inefficient process, but I enjoy the mental discipline that woodworking requires. Ayup, that pretty much sums it up. Nicely done! Link to comment
motoguy128 Posted May 25, 2010 Share Posted May 25, 2010 I remember making one of those in shop class in middle school. yours looks a lot better than mine did... and I didn't have the any hardware or cut-outs. It looks like every strip has a little different color stain. Was that on purpose? Link to comment
David Posted May 25, 2010 Author Share Posted May 25, 2010 It looks like every strip has a little different color stain. Was that on purpose? I didn't use any stain--it's walnut oil, spread evenly on all the wood. The different look of each strip comes from the different types of wood: walnut, maple, red oak, yellow oak, etc. Link to comment
Jerry Johnston Posted May 25, 2010 Share Posted May 25, 2010 Be careful you may want to change occupations to something more relaxing like woodworking. Link to comment
David Posted May 25, 2010 Author Share Posted May 25, 2010 Be careful you may want to change occupations to something more relaxing like woodworking. There are times when it holds much greater appeal than consulting! Link to comment
Quinn Posted May 26, 2010 Share Posted May 26, 2010 No jointer for the glued edges? Must be a really good blade on the table saw. Nicely done. --- Link to comment
hANNAbONE Posted May 26, 2010 Share Posted May 26, 2010 dB : you could sell 'em @ rallys'...kinda like a Kermit chair. Link to comment
Patallaire Posted May 26, 2010 Share Posted May 26, 2010 Made cutting boards like that for gifts one year, by the time I figured out the time involved and after I went to a craft show then to a store and realized what I could have bought them for, I vowed to not do that again. It was fun but...... Link to comment
Joe Frickin' Friday Posted May 26, 2010 Share Posted May 26, 2010 No jointer for the glued edges? Must be a really good blade on the table saw. Nicely done. The high-dollar saw blades do deliver a really nice cut these days. If you get a 200-tooth Oldham blade from Sears for $8, it wobbles and gives a terrible, useless finish. Instead, you go to Home Depot and pick up a Ridgid or Diablo 90-tooth blade for $70, and the cut comes out glassy smooth, as good as anything a planer/jointer could possibly give you. Link to comment
Lets_Play_Two Posted May 26, 2010 Share Posted May 26, 2010 I just put my sink measurements in the mail. Link to comment
David Posted May 26, 2010 Author Share Posted May 26, 2010 I just put my sink measurements in the mail. I'd be delighted. Link to comment
EddyQ Posted May 26, 2010 Share Posted May 26, 2010 Instead, you go to Home Depot and pick up a Ridgid or Diablo 90-tooth blade for $70, and the cut comes out glassy smooth, as good as anything a planer/jointer could possibly give you. Well, that is a little far fetched. A jointer should give you a much better (and flatter) surface than any tablesaw. A well tuned hand plane will do better than that. But, I do agree that a tablesaw with a decent blade will be good for a small edge joint. Maybe even better than a super smooth hand jointed edge, since it holds more glue. Nice job David ! Link to comment
Spike Posted May 26, 2010 Share Posted May 26, 2010 I'd be delighted. Careful, he charges by the hour. Link to comment
Joel Posted May 26, 2010 Share Posted May 26, 2010 I'd be delighted. Careful, he charges by the hour. And the inefficiency of the process has been well established. Link to comment
