ltljohn Posted May 22, 2010 Share Posted May 22, 2010 I need a new front tire. I found a couple of places on line with good prices and free shipping. My question is this. The tire size is 120/70/ZR17 but there are four choices with suffixes of C, G, U and K there is also another with no suffix that is $20 less. What do the suffixes indicate? Link to comment
StuGotz Posted May 22, 2010 Share Posted May 22, 2010 Not a tire expert, but your suffix's may be brand specific and motorcycle manufacturer specific.., If it were me , I'd contact the manufacturer for explanation. I've got tires on my RT with the designation B, which means BMW. You wouldn't want to use these tires on a Honda. I've used spec tires in the past with no suffix, but I'd never use one with a suffix I didn't know on my bikes. I have a set for use above 300mph and tested to 550 mph...these have an "X" on them... ( experimental) MB> Link to comment
StuGotz Posted May 22, 2010 Share Posted May 22, 2010 Update, look at this from another thread: http://www.largiader.com/shop/tires.pdf MB> Link to comment
ltljohn Posted May 22, 2010 Author Share Posted May 22, 2010 The tires are Metzler Z6, I could not find anything on the Metzler site. Link to comment
philbytx Posted May 22, 2010 Share Posted May 22, 2010 I wouldn't worry. The tyre is the correct size with the correct Z rating....go for it! Link to comment
Dan M Posted May 23, 2010 Share Posted May 23, 2010 It is brand specific specification. Ask on Metzeler's site they will probably respond quickly. I've used the plain ones without issue from Metzeler, Continental & Pirelli. Link to comment
GordonB Posted May 23, 2010 Share Posted May 23, 2010 Some mfgr's provide a 'B' fitment; the tire is designed with stiffer/sturdier sidewalls to handle the loads of a fully loaded two up touring bike. Link to comment
philbytx Posted May 23, 2010 Share Posted May 23, 2010 Here you go : The important stuff is that the tire should show both a Speed rating and a Load rating. Certain manufacturers may show a particular tyre size but for a particular manufacturer. Motorcycle Speed Ratings Speed Symbol Max Speed Speed Symbol Max Speed Speed Symbol Max Speed J 62 mph K 68 mph L 75 mph M 81 mph N 87 mph P 93 mph Q 99 mph R 106 mph S 112 mph T 118 mph U 124 mph H 130 mph V 149 mph W 168 mph Y 186 mph Z 149 mph Load Indexes (L.I.) L.I. lbs. L.I. lbs. L.I. lbs. 33 254 49 408 65 639 34 260 50 419 66 661 36 276 52 441 68 694 37 282 53 454 69 716 38 291 54 467 70 739 39 300 55 481 71 761 40 309 56 494 72 783 41 320 57 507 73 805 42 331 58 520 74 827 43 342 59 536 75 853 44 353 60 551 76 882 45 364 61 567 77 908 46 375 62 584 78 937 47 386 63 600 79 963 48 397 64 617 80 992 81 1018 82 1047 83 1074 84 1102 85 1135 86 1168 87 1201 88 1234 89 1278 90 1323 91 1356 92 1389 93 1433 94 1477 95 1521 96 1565 97 1609 98 1653 99 1708 100 1764 101 1819 Link to comment
