CruisinCruzan Posted May 20, 2010 Share Posted May 20, 2010 I am about to install a new Sirius Stratus 6 on my RT to replace a Roady XT. This radio comes with a cig plug that also acts as the FM transmitter (through the ground wire). Since i will be connecting the radio to the autocom I will not need this transmitting function. I would like to cut off the plug and wire it to my fuse block. Any electrical reason I could not do this? I know that Sirius would never say it was OK to modify one of their products.Thanks Link to comment
markgoodrich Posted May 20, 2010 Share Posted May 20, 2010 It's probable that the plug reduces the voltage going to the unit. If so, you can take the plug apart, find the two connectors inside, and solder wires to them...run them to power. I did that several years ago, wrapped the whole thing up in electrical tape, and it's still somewhere under my seat, powering up the sat radio. Link to comment
randy Posted May 20, 2010 Share Posted May 20, 2010 as noted above, the old roady's had a voltage reducer built into the plug. many people did as noted above. I actually purchased a much smaller correct voltage reduction item and hard wired that to my centech. that worked very well. sorry I do not remember were i bought the power converter, but it was very small footprint. Link to comment
CruisinCruzan Posted May 21, 2010 Author Share Posted May 21, 2010 Thanks for the suggestions. The specs say 9-12 V in and 5V out so it looks like plug surgery. Link to comment
RocketMoto Posted May 22, 2010 Share Posted May 22, 2010 XMFan.com has direct wire power supplies. We typically do a plug-ectomy. Remove the DC-DC power supply from the plug, wire to the input through a 2AMP fuse (you can go to your Centech) and shrink tube the entire assembly. Link to comment
