ESA Broken
Dave_C
I have a 2006 rt with the original ESA suspension. The rear Spring preload used to be adjustable with me and my pass. sitting on it. Then it would only adjust with no one sitting on it. Now it will not adjust at all (58,000 miles on the clock). Damping adjustment(comfort, normal, sport) still works fine. Can I just replace the device for preload adjust. Has anyone done it, how much$$$? Any photos or instructions? Or...any good experiences with after market/ESA adjustable shocks/rear spring?
CruisinCruzan
This may not be a hardware issue. The ESA system can sometimes need to be reprogrammed so that the preload works again. This is what happened to my system. This problem was more common with the analog systems that came on the 05-06 RTs. Once the change to a digital sensor was made it was less of an issue. With the mileage you have it may be worthwhile to look at an aftermarket system.
Take your bike to the dealer and let them check it on the computer. I just got mine done Friday in Grand Rapids. They fixed it! I spent $120 for 1-1/2 hours of computer time!
BTW....I replaced my shocks with Hyperpros with the ESA conversion. They are working great .......now!
It is also possible that a spent battery could cause the symptoms you describe. At idle the alternator may not be able to fully compensate for a failing battery.
Jay
