AndyS Posted April 27, 2010 Share Posted April 27, 2010 Can you guys tell me in VERY simple terms how to check my system (which I believe to be 2.4) for faults. Is it possible to use basic gear like multimeters? If it is similar to the older 1100 series I believe you get dips on the meter readback. If so, what do these relate to on this system. Thanks Andy Link to comment
Boffin Posted April 27, 2010 Share Posted April 27, 2010 Can you guys tell me in VERY simple terms how to check my system (which I believe to be 2.4) for faults. Is it possible to use basic gear like multimeters? If it is similar to the older 1100 series I believe you get dips on the meter readback. If so, what do these relate to on this system. Thanks Andy Sorry Andy, the 1150 uses a digital data stream for fault codes so the only DIY method is to use a GS911. Andy Link to comment
AndyS Posted April 27, 2010 Author Share Posted April 27, 2010 Aha! Thanks for that very prompt reply. Andy Link to comment
