Weaping from cylinder head gasket
roundy
Had the bike serviced by BMW on Friday and found after a long trip on her the above. Took the covers off, gave the gasket a good clean and the mating surfaces and so far seems to be sorted. Have a bad feeling though. Thought these gaskets should last ages??
You talking about the valve cover gasket--or cylinder head gasket? Valve cover will leak if the donut gasket doesn't seal properly around the spark plug opening.
Cyl head is whole nother issue--bolts must be torqued just so-so. Haven't heard of any leaking yet.
OK; I've re-used mine over and over with no leaks so far. But with the round rubber donut gasket, when you are installing the valve cover, if you pull it *away* from the motor while installing it, you should then remove the cover altogether, reposition the donut gasket, and then re-install in one smooth motion. Pulling back while installing will almost always dislodge the donut gasket to where it will be pinched by the cover. And leak.
Don_Eilenberger
And in installing the outer gasket - both surfaces and the gasket must be oil free. Any oil left on them provides a path for weeping.
I did clean the outer gasket well, i would have expected the dealer to do that but hey ho! I am hoping its sorted now but time will tell.
Just out of interest, if it was the inner gasket leaking i am assuming it would come from the center (where the plug goes). My leak was (is) at the bottom of the cover.
Yes--unless it dripped or blew around there. If its coming from the bottom for sure, you better check the main gasket and/or replace.
