R1200RT Left switch failure - need replacement
sb955i
Hi All,
I put a WTB up in the classifieds, but i thought i'd followup here as well and ask if anyone knows of any R1200RT's parting out. I need a switch assembly, left bar ( cruise, no esa ).
Anyone? Please PM me.
Thanks eh!
scb
I need one of these, possibly from a trashed assembly. It's the momentary switch which is inside the assembly. I will install/ resolder if i can get one. Could be off any beemer i suppose...
cheers
scb
Pretty expensive, just did mine last fall, don't remember the exact cost but around $300 or so comes to mind.
Fran
PS Make sure you get the right one, there are many variations available due to options that bikes may or may not have.
Fran
Here's a tip -- hard learned. The switch for the warning flashers (if so equipped) is the same switch. Finding a used one is a tough hunt. I found a left side assembly at Boneyard and it was about $50 because the cruise was not functioning. Have not seen one since. Good luck.
This switch can be purchased from a supplier and replaced. What I can't remember is where I've read it. Someone has done this.
Is there any clues as to the original manufactuer on it?
I believe you will get the switch from DIGI KEY Now this link is the one for the indicator switch on a R1200RT, but I imagine you will find the cruise switch here too. I did the LH Indicator switch a while ago. You say it is for the cruise control switch? Do you mean cruise ON/OFF or the other two RES/SET ?
  • 1 year later...
Thanks in large part to this thread and a few others, I should have my signal switch fixed soon... I don't know if this will help anyone, but I am attaching my best attempt at helping others troubleshoot their turn signals by way of video... Tell me what you think. I was also able to purchase the switch from digikey... I'm going to have to melt the resin out and use that white base for the new one though. Okay, you may now watch and laugh.
Jay
