difference between '05 and '06 R12RT
bimmerbeemer
bimmerbeemer
A friend is interested in buying a R1200RT, either '05 or '06 model and wonders what, if any, differences exist between the two models.
Any tips?
Thanks,
Alan in NC
LeftCoastMan
Yes, there isn't much difference between the two. I have no clue about the horn, but it is wimpy. LOL.
So, if you're to make a decision, you can assume that the 06 has some of the kinks removed from the 05. And also, you need to see what differences there are in options between the two. ESA/non-ESA. Radio. Etc.
The switch from the loud dual horn of the '05 to the rather inadequate single horn occurred in either Jan. or Feb. of '06. Also, I believe the later '06 models had the sensor/software change which eliminated the spurious low oil warnings. That should have been fixed under warranty on any used bike you are considering.
IIRC, there were no differences in available options or colors from '05 to '06.
Tom
Exploreinman
'05 Dual Horn / '06 Single Horn
'05 Hazard Switch / '06 Hit both blinkers to activate Hazards
Also in '06 the termperature sensor was moved. The '05 model reads 6 degrees under the accurate temp, the '06 model reads 6 degrees over the accurate temp.!
6 degrees Under?
Mine is 6 over... since it is often "chilly" here in the intermountain west... I like that... keeps me warmer- so I chose not to do the sensor relocation,
Just a quick note on the dual horn... early 06 models (mine has a build date of 09/05 do have the dual horn set up... as earlier stated, sometime in calendar year 06, the later ones went with the wimpy single horn setup.
Chris
Guess I'm lucky as my early '06 has always read within 2o of the true temp.
Tom
I have a '06 manufactured in Feb 2006. It had the wimpy horn until I installed dual highway blasters. No separate hazard switch.
