jpsurf Posted April 12, 2010 Share Posted April 12, 2010 2004 R1150RT not firing on right cylinder. Swapped primary spark plugs, problem continued. Swapped stick coils, still not firing. Removed right injector and it is delivering fuel.Checked throttle cables on TB and reseated. Disconnected battery ground, reconnected, and reset wide open throttle position with ignition key on. Any ideas would be appreciated. Link to comment
DonW Posted April 12, 2010 Share Posted April 12, 2010 You said you did it, but the few times this EXACT symptom has occurred on my and my buddy's bike, it was the throttle cable not being seated on the Right side TB. Don Link to comment
dan cata Posted April 12, 2010 Share Posted April 12, 2010 2004 R1150RT not firing on right cylinder. Swapped primary spark plugs, problem continued. Swapped stick coils, still not firing. Removed right injector and it is delivering fuel.Checked throttle cables on TB and reseated. Disconnected battery ground, reconnected, and reset wide open throttle position with ignition key on. Any ideas would be appreciated. Measure the resistance across the injector. 16,5 +/- ohms Link to comment
dan cata Posted April 12, 2010 Share Posted April 12, 2010 You said you did it, but the few times this EXACT symptom has occurred on my and my buddy's bike, it was the throttle cable not being seated on the Right side TB. Don or that ) Link to comment
