Carroll Posted March 19, 2010 Share Posted March 19, 2010 I have a 2003 R1150rt and my grips need replaced. Has anyone replaced just the rubber grips on their heated grips. I checked the OEM grips and it looks like you have to buy the entire heated grip assembly. Can anyone suggest a good aftermarket replacement for the rubber grip. Link to comment
Ewell D. Posted March 19, 2010 Share Posted March 19, 2010 Tennis racket re-gripping tape. Comes in many textures and thicknesses. I have a fairly thick one on my grips and have not noticed that it affects the heating of the grips. I went this route to try something thicker after the foam grip covers I bought ripped while installing them. Ewell Link to comment
tomk99r11 Posted March 19, 2010 Share Posted March 19, 2010 I have installed grip heater grids (not new grips with heat or the BMW heated grips) on my R1100 and then later removed the grips for replacement. Just took my time, used air and screw driver to work the grip loose. Worked fine. I can see though that you could damage the grid if you aren't careful. As for the tennis racket grip tape, I have that on my DL with the same heat grid mentioned above. Works fine and does not seem to affect the heat transfer. Good luck with whatever you end up with. Link to comment
Steve W. Posted March 19, 2010 Share Posted March 19, 2010 Instructions Cheers Steve W. Link to comment
Steve W. Posted March 19, 2010 Share Posted March 19, 2010 Sorry, here's the link Grip Replacement Cheers Steve Link to comment
jfremder Posted March 20, 2010 Share Posted March 20, 2010 They also make tubular tennis racket overgrips. $5 at the sporting goods store. ~30k mi. per set Tennis racket re-gripping tape. Comes in many textures and thicknesses. I have a fairly thick one on my grips and have not noticed that it affects the heating of the grips. I went this route to try something thicker after the foam grip covers I bought ripped while installing them. Ewell Link to comment
Bronx Cheer Posted March 20, 2010 Share Posted March 20, 2010 I put on some grip puppies. They are a real PIA to put on. Use lots of soapy water. Grip Puppy Link to comment
R1150RT_MLC_Response Posted March 20, 2010 Share Posted March 20, 2010 I have used something like Grip Puppies but they were Harley accessories. Went on pretty easily, no soapy water or other lubricant required. About AUD$10. Inexpensive solution. Regards Ian Link to comment
Starfighter Posted March 21, 2010 Share Posted March 21, 2010 on my '04 RTP,I bought new grips at the BMW shop pretty cheap. They were for a K bike and fit perfectly. I sprayed the inside with hair spray before applying...... Link to comment
yaron Posted March 21, 2010 Share Posted March 21, 2010 I ordered on the net new replacing for the grips and foot rest rubber. http://www.motobins.co.uk/ Yaron Link to comment
beemer_me_up Posted March 21, 2010 Share Posted March 21, 2010 on my '04 RTP,I bought new grips at the BMW shop pretty cheap. They were for a K bike and fit perfectly. I sprayed the inside with hair spray before applying...... I just did the same thing. 2 Right side grips from the k-1, $10.00 each, a little hair spray and as good as new. Just be carefull removing the old grips. http://www.maxbmwmotorcycles.com/ Link to comment
Carroll Posted March 21, 2010 Author Share Posted March 21, 2010 Thanks for all the great information. Link to comment
