Brake line replacement - wisdom pls.
Lineareagle
Lineareagle
I am going to replace the top, front brake line on the '06 GSA, non-ABS and do a fluid change at the same time.
Anyone done something similar and have any words of wisdom?
My "words of wisdom" are:
If you don't already have em, go with braided steel lines. It really does make a difference.
I remember replacing the rubber lines on my sportbikes with steel braded. HUGE difference in terms of feel and overall strength. I think most sportbikes now probably comes with SS lines.
My R1200RT came with SS braided lines. I think there's a reason for that.
Besides, I think you cna probably get aftermarket SS lines for less than OEM rubber lines.
Lineareagle
It is not so much what to replace it with as to How.
Any steps better for making the bleeding easier? After putting on the new line?
CoarsegoldKid
I just changed my brake and clutch lines on my ducati. I bought them from cyclebrakes.com. Mine were custom sized but stock sizes are available too I think. Either way stockers can be measured. I gave them the measurements and color. The next day I had them on the bike. They are made in California. Galfer is the manufacture. Bleeding the clutch involved a C-clamp and bolt to hold the piston in. The brakes lines filled quickly. I did use wooden spacers instead of the disc to hold the pistons in place. I do the same for bi-annual brake bleeds. Easy work. No assistant is necessary.
