Help, Ohlin damper adjuster under seat
mos
Just installed a set of Ohlin shocks on the 05 R12RT. I want to install the damper adjuster under the seat and not near the left passenger foot peg. I think I have seen a post on this but can't find it.
Mike
You certainly can do that. I had Ohlins installed on my '06 RT last summer and they put the pre-load adjuster under the seat. I do not have any pictures of it and my bike's still in winter storage. Don't know the thread you're referring to; have you tried searching for "Ohlins" in the Hexheads forum?
Dave_zoom_zoom
Here you go Dhttp://www.bmwmoa.org/forum/showthread.php?t=38321&highlight=ohlins&page=2ave,
Mike
Thanks for trying to pass that info. along Mike!
It seems I'm not able to access that reference. Most likely because I'm not an MOA member.
Guess I'll just let the preload adjuster lay on top of the back fender.
Thanks for trying!!!
Dave
Mike
On the R12RT, there's a bracket for the adjuster straight behind and slightly up from the diagnostic port.
Dave_zoom_zoom
Mike
Ahhh yes! Should work well. Thank you Al!
CoarsegoldKid
My Ohlins adjuster is ahead of the footpeg so I could get to it while the side cases were on. The instuctions have it behind the footpeg and it did have interference with the side case for some reason.
