ultrahuck Posted January 25, 2010 Share Posted January 25, 2010 Just about to do my first valve adjust and plug change on my 2004 R1150RT. Very low mileage at 6800. I know there are plug discussions on here but would appreciate input on best plugs to use for the prim and sec. plugs on my twin spark RT? Thanks in advance. Tom Link to comment
Heyfrank Posted January 25, 2010 Share Posted January 25, 2010 Look up above your post at archive for r bikes. primary ngk bkr7 ekc-n. secondary Bosch yr6 lde.Hope this helps. Link to comment
ultrahuck Posted January 25, 2010 Author Share Posted January 25, 2010 Thanks Heyfrank. Link to comment
Dick_at_Lake_Tahoe_NV Posted January 26, 2010 Share Posted January 26, 2010 Denso Iridium IXU22. And here's a place to buy them. http://www.optionsauto.com/prodinfo.asp?number=ND-IXU22 Just remember the Spark Plug Cap is integral with the Coil. So when you change plugs, unplug the small wiring-connector from the Cap/Coil, and then use the "Puller tool" to remove the cap/coil from the Spark Plug. Do not drop the Cap/coils. Link to comment
