Oil Filters in Oz
tazplas
Hi People
This is probably aimed at those in Downunder but i am wondering what oil filters fellow riders use. I have just purchased another filter from the dealer at $31 and i reckon there has to be something here Downunder that is available for less.
No real luck on web searches for Mahle OC91 filters in Oz.
It's frustrating to see 5 filters for $40 US or $10 US each but by the time i add freight etc we are nearly back to the original cost.
Ideas from/for Downunder?
Yeah i also know that the cheapest thing about a BMW is the owner. How true! :grin:
Cheers
Steve
Oilheads filters are the same size as many automobile filters.
About the only thing that distinguishes the BMW filter is that it lacks an anti-drainback valve (it doesn't hurt anything if you use a filter with anti-drainback, but it doesn't help anything either, due to the inverted position of the filter on the bike).
Among the very many automobiles that use exactly the same oil filter size is my wife's 2004 Toyota Sienna minivan, which was available with only one engine size.
So if you can go to your autoparts store (do you call them auto bits stores?) and look for a filter for that minivan, you'll have what you need.
that minivan takes a AC pf53 just like the oilhead. you can also use any oil filter that will fit a non turbo Chrysler pt cruiser, like the ones mentioned above.
Here ya go
FRAM is the correct FRAM but hard to find at WallyWorld. PH6063
FRAM is readily available and works PH3614
AC DELCO PF-53
NAPA 1348
Mobil-1 M1-102
BMW 11.42-1 460 843 or 845
Mahle/knecht/microstar/tecafiltre (original part) OC91
Champion (of motorcycle range) C301
Purflux LS188B
Hiflofiltro (from Thailand) HF-163
Mann-Hummel MW712
Detlev Louis (Germany) 10050195
Toyota 08922-02004 or 90915-YZZB9
AMSOIL SMF122
Bosch 3330
WalMart ST3614
Purolator L10241
AC PF53
Thanks All
Have managed to track down a filter supplier for Mann-Hummel here in Hobart. Haven't got a price yet so importing from the US could still be the solution. However, at least if i buy them from here i can be sure they have been adjusted to swirl in the right direction since we are in the Southern Hemisphere.
Hadn't allowed for that in the past!!! :dopeslap:
Other makes such as Fram. Mobil 1, Champion etc just gets you funny looks from auto stores and there is next to nothing on the net for here in Oz. I have tried all the names and the closest i got was tracking down Mann-Hummel and Purolator (which directed me to Mann-Hummel)
So there we go. I am awaiting prices from a local source for a MW712.
Cheers and thanks again
Steve
