Good name for the "new" R bike BMWs
johnlt
Posted
We've got airheads, oilheads and hexheads. What are we going to call the new BMWs. "Camheads" possibly?
Posted
Ready to break at a moment's notice?
Posted
:rofl:
:cry:
Have ya seen the new Yammie 1200 ADV bike???
Posted
Me likey!!!!!
Posted
With all that fancy profile grinding of the cams and followers and radial valves - "knucklehead" should do it!
Dennis Andress
Posted
I like Knuckleheads...
Posted
and when they break we'll call them "Deadheads".
Posted
+1 on Camheads... So when do we get the new sub-forum???
JT
Posted
My vote goes for shaftheads.
Cam is a slang term for camshaft.
By using the word shaft, it connotes other meanings that may or may not be applicable as the new engine becomes more common.
Posted
The shape of the cover makes me think of Comma Head.
Posted
If the cam lobes are conical, how about Cone Heads?
Bob
Posted
How about "Shim Bucket"
Posted
If they have problems right away, they could be called holeNdheads
Posted
The new motor has dual OVERHEAD cams.
I'd call them overheads.
Mikko
Posted
This is one of those topics that took some reflection before a measured response. The most controversial feature of the new R motors is using shims to adjust the valves, right? So 'Shim Head' must be a consideration in my book. :lurk:
Posted
Shims to adjust the valves?
Expensehead, buckethead and hardhead is appropriate.
Posted
Mikko
My choice also. It describes their most significant feature which would make it the more logical.
Although, coneheads is pretty funny and these newer bikes are becoming laughable at times. :)
Posted
DOHCheads (duck/heads)
Duckheads
Posted
My vote goes for ShimHead. For the DIY crowd THAT is probably the most significant aspect of the new model.
From some future do-it-yourself doc (yet to be written):
"Valve adjusment: Steps 39-53: cam shaft removal:
Make sure that the index lines on the right cylinder cam sprocket are facing outward and that the No. 2 piston is at TDC on the compression stroke. Remove the cam sprocket bolts from the intake and exhaust camshafts, being careful not to drop the cam sprocket bolts into the crankcase. Turn the crankshaft one full turn, remove the other cam sprocket bolts from the camshafts. Turn the left cylinder cam chain tensioner lifter shaft fully in (clockwise) and secure it using the stopper tool. Remove the bolts and cam guide. If necessary, remove the cam sprocket from the camshaft. Mark the camshaft holder A for identification at installation. Loosen and remove the camshaft holder B bolts gradually in several steps and remove the camshaft holder B. Loosen the camshaft holder A bolts and then remove the camshaft holder A..." **
** Note: plagerized from the ST1300 shop manual
Posted
The “oilhead” and “hexhead” have cam in head, so “Camhead” isn’t really appropriate, isn’t really a distinguisher. Hexhead was based on a look (of the valve cover), but oilhead was base on a functional design change (from airhead). Tough one to sort out. I guess I’d vote “Shimhead.”
Posted
That's good. Is it possible a valve adjustment with shims is an attempt by BMW to discourage DIY and force owners to bring them to dealers for maintenance?
Shafthead could be the best name for it.
I can think of one cage that is at this level now. The Toyota Prius has no owner serviceable areas on it. It must go to the dealer for maintenance, no independent shops will touch it.
Posted
If so, then how about "DealerHeads"? ;)
Posted
If the valve covers are pot metal, would it be a pot head?
Posted
That seems like a crappy deal. I don't think it would be wise for motorcycle manufacturers and developers to engineer machines that are unserviceable by DIY Owners. It takes away half the hobby!
Then again, we all have been drinking the kool-aid and probably will eventually be forced to buy crazy, dealership saving machines in the future. Lets just hope that someone can hack the safety tape.
Posted
I consider the boxer one of the DIY mechanic's best friends. Compared to all the japanese bikes I've owned, the boxer is way easier to maintain. Did my valves for the first time solo last night and what a breeze. Since we aren't going to have to remove the cams on the new motor it's still going to be quite easy compared to a metric cruiser where a valve check is a near total disassembly to get to the valves.
I just dont see the "shaft" part.
I had read on some other board people calling them "camheads" so I assumed that was more universal. You do see the cam on the new engine when you take the valve covers off. Besides, camhead sounds better than shimhead which sounds suspiciously like shi*head.
Perhaps we should run a poll!
JT
CoarsegoldKid
Posted
SHIMHEAD. Done. Finished. When it becomes coolant cooled we can call it a COOLHEAD.
Posted
I'd like to suggest "Uber-Head"
Posted
Modern.
Posted
Personally, I like SHIMHEAD, but I have a vested interest in that one. I earned the knickname from a parts man at a Nissan dealer I worked at in the 80's because I insisted we stock the 30 odd shim sizes I was always using when rebuilding Maxima front wheel drive automatic transmissions. However, despite my fondness for my unique knickname/username, I will be willing to share for a fee.....
Posted
Overheads
Believe it or not, I woke up at 4 a.m. this morning and this popped into my 'head': DoubleOverHead. I liked the double (triple??) entendre of being both a DOHC and the doubled overhead (labor) of setting the valves. Its a bit long though... ShimHead still works too.
Posted
It's not so much that shim bucket valves are unservicable, as it is that they are more complex and require more effort to service - when they need it. And there is probably little difference between shim mechanism on the new beemers and the shim mechanism on thoxe Suzi 650s.
Checking the valve clearance is not much of an issue, and would be easier on a new beemer because the heads are more accessible. Setting them, if they need setting, is another issue. But, these mechanisms *should* require less frequent setting.
My concern would be that up to now, setting the valve clearance on a boxer has been an integral part of the tuning process (along with TB sync, etc.) to reduce surging and enhance smoothness. But the shims come in defined sizes (you have to buy several different sizes if you want to fiddle) and are not that easy to change. In some cases, the DIY process would be to remove the covers, check the clearance, go to the dealer, get the correct size shims, go home and install them.
And for those who say that surging has been fixed in the 1200's, my riding buddy with an '07 RT would unfortnately disagree.
Posted
Bob
I vote conehead as well..........because.........I don't know??!!
It's just a catchy (?) word.
Posted
Overheads
Doppelknocker
Posted
BMWMOA had a poll :
As far as a new name for the engine/forum :
Camhead came 1st
Arrowhead came 2nd.
I like Arrowhead....as it does look like an Arrowhead and Camhead is, IMHO, redundant!
Posted
BMWMOA had a poll :
Camhead came 1st
Arrowhead came 2nd.
I liked Camhead, but maybe that's because I suggested it and won a shirt when it came first in the MOA poll. :grin:
Posted
Yah - I think camhead is more descriptive as it calls attention to the cams as being different than the other engines. It's the first mass-market DOHC boxer and it's a short, sweet name.
Poll!
Posted
Hammer Head - use your imagination.
Posted
If the dealer conspiracy theorists are correct, and the new motor is designed to discourage DIY service, than they should be called "overheads," simply because bringing them in for service will help to offset the dealers' overhead expenses.
Posted
Oilhead 3.0
Posted
Five pages of head talk and nobody suggested, CrackHEAD.:dopeslap: I know go away. I'm just say'n.
Posted
Or, a cross between shim head and a shaft head is???? oh, I can't do it. Shame on me...
Posted
How about...Faster than the rest of you slugs...?
Posted
Doesn't HD already own BOTH those appelations? :grin:
