ozmojo Posted January 12, 2010 Share Posted January 12, 2010 The funnel is on sale for 34.95 . Thats 15.00 off . Sorry if it's old news . Link to comment
Uncle Beemer Posted January 12, 2010 Share Posted January 12, 2010 $35.00 For what is nothing more than a plastic funnel and a rubber plug. Yep, that's a real deal! Link to comment
NonComp Posted January 12, 2010 Share Posted January 12, 2010 For the same price, you can get something like this: MityVac Link to comment
Jim VonBaden Posted January 12, 2010 Share Posted January 12, 2010 $35.00 For what is nothing more than a plastic funnel and a rubber plug. Yep, that's a real deal! Mike doesn't use a rubber plug. His is a BMW type plug that screws in. Try and make one and see how much your time and effort is worth. Also, a Mightyvac is useless for this job. Jim Link to comment
NonComp Posted January 12, 2010 Share Posted January 12, 2010 Oops, sorry for the red herring. Link to comment
KDeline Posted January 13, 2010 Share Posted January 13, 2010 $35.00 For what is nothing more than a plastic funnel and a rubber plug. Yep, that's a real deal! Mike doesn't use a rubber plug. His is a BMW type plug that screws in. Try and make one and see how much your time and effort is worth. Jim I did years ago, it was very easy and cheap. Did have to use silicone after it came apart once using JB Weld. Luckily I was just about to use it instead of happining during a bleed. Link to comment
Jim VonBaden Posted January 13, 2010 Share Posted January 13, 2010 $35.00 For what is nothing more than a plastic funnel and a rubber plug. Yep, that's a real deal! Mike doesn't use a rubber plug. His is a BMW type plug that screws in. Try and make one and see how much your time and effort is worth. Jim I did years ago, it was very easy and cheap. Did have to use silicone after it came apart once using JB Weld. Luckily I was just about to use it instead of happining during a bleed. The caps are sold only in pairs at about $50, not exactly cheap. Unless you use a rubber plug. Jim Link to comment
ozmojo Posted January 13, 2010 Author Share Posted January 13, 2010 It's a good thing I didn't say it was an oil funnel...you know where that would have led. Link to comment
KDeline Posted January 13, 2010 Share Posted January 13, 2010 $35.00 For what is nothing more than a plastic funnel and a rubber plug. Yep, that's a real deal! Mike doesn't use a rubber plug. His is a BMW type plug that screws in. Try and make one and see how much your time and effort is worth. Jim I did years ago, it was very easy and cheap. Did have to use silicone after it came apart once using JB Weld. Luckily I was just about to use it instead of happining during a bleed. The caps are sold only in pairs at about $50, not exactly cheap. Unless you use a rubber plug. Jim I got lucky then, I was able to get only one, can't remember what I paid for it, plus 20% off at Chicago Cycle. Link to comment
Uncle Beemer Posted January 13, 2010 Share Posted January 13, 2010 $35.00 For what is nothing more than a plastic funnel and a rubber plug. Yep, that's a real deal! Mike doesn't use a rubber plug. His is a BMW type plug that screws in. Try and make one and see how much your time and effort is worth. Also, a Mightyvac is useless for this job. Jim Jim, I realize the part that is used is threaded,but still think $35.00 is way to expensive. YMMV Link to comment
NoHeat Posted January 13, 2010 Share Posted January 13, 2010 I realize the part that is used is threaded,but still think $35.00 is way to expensive. YMMV Funnel is $6.27 at McMaster. #2 rubber plug with hole would sell for pennies if you can find just one, for example at a lab supply store, while a pkg of 25 goes for 6.60 at McMaster. So for $12.87 total you get what you need, plus 24 extra plugs that you won't know what to do with. You do have to drill out the stopper hole a little bigger. It isn't threaded, but it doesn't matter. It works great. Link to comment
ltljohn Posted January 14, 2010 Share Posted January 14, 2010 I realize the part that is used is threaded,but still think $35.00 is way to expensive. YMMV Funnel is $6.27 at McMaster. #2 rubber plug with hole would sell for pennies if you can find just one, for example at a lab supply store, while a pkg of 25 goes for 6.60 at McMaster. So for $12.87 total you get what you need, plus 24 extra plugs that you won't know what to do with. You do have to drill out the stopper hole a little bigger. It isn't threaded, but it doesn't matter. It works great. Here are the part numbers for McMaster Carr 4005T5 1 Each Quick-drain Clear Polymethylpentene Funnel, 8 Oz Capacity, 4-7/16"top Od, 7-3/4"o’all Height 9545K27 1 Pack Tapered Push-in Round Rubbber Plug, Through Hole, Size 2, 13/64" Hole Size Link to comment
Matts_12GS Posted January 14, 2010 Share Posted January 14, 2010 I realize the part that is used is threaded,but still think $35.00 is way to expensive. YMMV Funnel is $6.27 at McMaster. #2 rubber plug with hole would sell for pennies if you can find just one, for example at a lab supply store, while a pkg of 25 goes for 6.60 at McMaster. So for $12.87 total you get what you need, plus 24 extra plugs that you won't know what to do with. You do have to drill out the stopper hole a little bigger. It isn't threaded, but it doesn't matter. It works great. Here are the part numbers for McMaster Carr 4005T5 1 Each Quick-drain Clear Polymethylpentene Funnel, 8 Oz Capacity, 4-7/16"top Od, 7-3/4"o’all Height 9545K27 1 Pack Tapered Push-in Round Rubbber Plug, Through Hole, Size 2, 13/64" Hole Size I made two of these from John's part #s. Who wants to come to FL and do a brake and clutch bleed tech day? Link to comment
Jim VonBaden Posted January 14, 2010 Share Posted January 14, 2010 Yeah, and RightSpin, a member here, used to sell them for $50, an no one complained. Oh well, use whatever works for you. I just remember how freeked out people got when they found out how much the caps cost. By the way, I have used the rubber stopper set-up, and it works OK as well. Jim Link to comment
DrPaul Posted January 14, 2010 Share Posted January 14, 2010 1- Suck out old DOT4 with turkey baster. 2- Add fresh DOT4 to fill ring. 3- Open caliper bleed valve - keep topping off ABS reservoir until fluid runs clear. 4- Close caliper bleed valve. 5- Top off ABS reservoir to fill ring. 6- Replace cap and wipe up any spillage. 7- You are done. Who needs a !@#$%^&* funnel??? Link to comment
Uncle Beemer Posted January 15, 2010 Share Posted January 15, 2010 Yeah, and RightSpin, a member here, used to sell them for $50, an no one complained. Oh well, use whatever works for you. I just remember how freeked out people got when they found out how much the caps cost. By the way, I have used the rubber stopper set-up, and it works OK as well. Jim Jim, I bought your DVD for I think $25.00. I know you put alot more effort and time into producing it, as compared to the funnel,it just don't add up to me. Link to comment
pjw73nh Posted January 25, 2010 Share Posted January 25, 2010 NOheat & Ltljohn, Tnx for the great info. I have a question. McMaster has two of the long stem funnels. A 2 oz one (4005T3) 2 oz Funnel and the 8 oz one you recommend (4005T5). 8 oz funnel Shipping was about $5 to NH. I was wondering if you had any issue with the rubber stopper not staying in tight enough with the added weight of the larger funnel, and the brake fluid in it. I have not used this setup before, so I don't know how tight the rubber stopper setup is. If it is not tight, I would think the smaller of the two funnels would be the best option as it is less likely to tip over. Then again, not having done this before, I don't know how fast the brake system will "drink" the fluid, and 2 oz may be too little of a reserve. Also I picked up a #2 stopper at Home Depot for $1 or so. , When I get my funnel, thanks to a tip I found somewhere here, I will freeze it and drill a hole. I think most hardware stores have these stoppers too. Any thoughts or comments? Thanks Link to comment
NoHeat Posted January 26, 2010 Share Posted January 26, 2010 pjw, I've had no problem with the bigger funnel tipping over while performing the brake service. A two-ounce capacity funnel would drain way too fast on my 1150 because the servo-assist brakes work as a splendidly fast power-bleeding setup. Freezing then drilling the stopper works well. Just be sure to find a way to drill it safely -- I probably held mine in a bench vise while drilling. Link to comment
