Final Drive Oil
gordiet
gordiet, that would depend on the make & model & year of the motorcycle you are riding.. What you got there?
If this is a new 1200 hexhead then first one at the run in check..
Twisty
gordiet, the latest (BMW) service sheet I have shows final drive gear oil change every 20,000KM (about 12,000 miles)..
A good way to set up 1200RT final drive gear oil changes is every rear tire change as the rear wheel has to come off anyways.. That might be plus or minus a little but that is a great time to do both..
Twisty
