r77toy Posted December 27, 2009 Share Posted December 27, 2009 Looking for a wire to trigger a relay, Hot only after the engine is running. '97 1100 RT Thanx Link to comment
T__ Posted December 27, 2009 Share Posted December 27, 2009 r77toy, about only one choice-blue wire from alternator.. Unless you can live with on with ignition but off during cranking then on after running that would be the headlight feed wire.. Twisty Link to comment
r77toy Posted December 28, 2009 Author Share Posted December 28, 2009 Headlight feed wire will work, Thanx Link to comment
Haynes Posted December 28, 2009 Share Posted December 28, 2009 If you want something that is live when the ignition is on, you can also take a wire from the horn fuse. I think it's fuse #4. Link to comment
r77toy Posted December 29, 2009 Author Share Posted December 29, 2009 That's where I got it. #4 Link to comment
