twowheelsonly Posted November 22, 2009 Share Posted November 22, 2009 I am curious if the throttle should operate the same as when the heat is on, my grips heat up but the throttle seems to drag and not rotate freely as it does when the heat is off. is there a way to service this and what is the procedure. Thanks for your help Link to comment
jfremder Posted November 22, 2009 Share Posted November 22, 2009 Do you have a throttlemeister or other friction throttle lock? Link to comment
Selden Posted November 22, 2009 Share Posted November 22, 2009 Do you have a Throttlemeister installed? If so, loosen the screw on the throttle housing, and move it in slightly. Link to comment
twowheelsonly Posted November 22, 2009 Author Share Posted November 22, 2009 No, although the fellow I bought the bike from did have one and he removed it cause he did not like it.. I don't have the throttle lock as he did not have it anylonger Thanks! Link to comment
Boffin Posted November 22, 2009 Share Posted November 22, 2009 The heater expands the throttle tube jamming it between the end-weight and the controls. You need to either slacken the controls off and move them inboard a little or take the lazy way like I did and put a thin washer under the bar-end weight to give a little more space. Andy Link to comment
twowheelsonly Posted November 22, 2009 Author Share Posted November 22, 2009 Thanks for all the input.. I ordered a service manual but do not have it, Question.. how do you remove the counter weight.. Thanks! Stewart Link to comment
Boffin Posted November 22, 2009 Share Posted November 22, 2009 Just unscrew the allen bolt in the end. Andy Link to comment
Mark K Posted November 22, 2009 Share Posted November 22, 2009 Just unscrew the allen bolt in the end. There could be some blue loctite on that one, so it could be a little stubborn.... Link to comment
Ebola Posted November 23, 2009 Share Posted November 23, 2009 You might want to spray some lubricant in there while you have the weight off. It made the throttle action much smoother. Also, make sure the grip is not touching the weight. Sometimes the constant outward force of your hand moves the grip so it contacts the end weight. Link to comment
