flars Posted November 22, 2009 Share Posted November 22, 2009 I need the tool that keeps the clutch housing (flywheel) from turning when you are torquing up the bolts. What did you guys use -did you make one up, or did you buy one? Link to comment
Boffin Posted November 22, 2009 Share Posted November 22, 2009 Try a wooden wedge between the case and the starter gear. Andy Link to comment
philbytx Posted November 22, 2009 Share Posted November 22, 2009 What they said plus.... HERE are instructions for a "fancy schmancy" TDC flywheel tool. I made one up for when I R&R'd my HES Link to comment
OoPEZoO Posted November 22, 2009 Share Posted November 22, 2009 What they said plus.... HERE are instructions for a "fancy schmancy" TDC flywheel tool. I made one up for when I R&R'd my HES That only works if the transmission is attached to the engine Link to comment
philbytx Posted November 22, 2009 Share Posted November 22, 2009 Duh! That's what I get for doing a "cursory read" Link to comment
NonComp Posted November 22, 2009 Share Posted November 22, 2009 I need the tool that keeps the clutch housing (flywheel) from turning when you are torquing up the bolts. What did you guys use -did you make one up, or did you buy one? Are you talking about torquing the flywheel bolts or the clutch bolts? If the latter, you can insert a bolt through the flywheel into a hole in the crankcase that is there for that purpose. Link to comment
flars Posted November 22, 2009 Author Share Posted November 22, 2009 I am trying to torque the 5 FLYWHEEL bolts - the ones that take 29 lb-ft, plus 32 degrees. Link to comment
NonComp Posted November 22, 2009 Share Posted November 22, 2009 I am trying to torque the 5 FLYWHEEL bolts - the ones that take 29 lb-ft, plus 32 degrees. I'd be tempted to use the bolt through the flywheel. I guess you could also put a ratchet with an extension on the other end of the crank (at the pulley for the alt. belt) and place it so that it would contact the floor or wooden blocks to prevent rotation. Link to comment
94aero Posted November 22, 2009 Share Posted November 22, 2009 I used a 1/4 x 3 inch bolt with the head cut off. works great! Link to comment
