noel Posted November 14, 2009 Share Posted November 14, 2009 The instructions say to use anti seize before threading the replacement screws into the brake/clutch reservoir. Is this really necessary? Why? I'm just really curious as to why. Especially since the existing one does not. Link to comment
T__ Posted November 14, 2009 Share Posted November 14, 2009 Noel, not sure it is absolutely necessary but not a bad idea.. Those small screws can gall easily if tightened on dry threads,, a small amount of anti seize can prevent galling of the threads & make future removal much simpler.. There is also the corrosion effect of brake fluid (assuming your clutch uses brake fluid rather than clutch oil).. A little anti seize can help prevent brake fluid from quickly rusting up the screw threads.. Twisty Link to comment
noel Posted November 14, 2009 Author Share Posted November 14, 2009 Thank you for your advise and clarification. Cheers. Link to comment
