NORMBATES Posted November 8, 2009 Share Posted November 8, 2009 OK - I give up - why does the gear indicator have an "E" instead of a "6" ? Or, is mine the only one ? Thanks again, Norm Link to comment
russell_bynum Posted November 8, 2009 Share Posted November 8, 2009 Error. The gear indicator only goes to 5. It doesn't know what 6th is so it shows E for error. Link to comment
ozbmw Posted November 8, 2009 Share Posted November 8, 2009 Theyre pulling your leg - the earlier 1150's etc displayed an "E" as the 6 gear/overdrive. This was changed to 6 in later models - its only a letter instead of a number - the only real difference - its commonly accepted as being for 'economy' but knowing the Germans its anyones guess. Link to comment
elkroeger Posted November 8, 2009 Share Posted November 8, 2009 Excessive. You might want to slow it down a bit. Egregious, perhaps? Esoteric. Express. Expletive. Get out your websters - there's lots of humorous entries... Link to comment
EffBee Posted November 8, 2009 Share Posted November 8, 2009 It's German. It stands for einuselessgearen. Link to comment
NonComp Posted November 8, 2009 Share Posted November 8, 2009 It's German. It stands for einuselessgearen. I just knew that it had to be a word with 5 or more sylables ending in 'en'. Link to comment
lvnvbiker Posted November 8, 2009 Share Posted November 8, 2009 Einspeedenticketengetter? Link to comment
tallman Posted November 8, 2009 Share Posted November 8, 2009 You have one of the rare RID's where the diode bar was put in the wrong place. Simply envision the top one moved to the lower right of the E and you have a six (6). I'd keep it. Link to comment
Paul Mihalka Posted November 9, 2009 Share Posted November 9, 2009 The real reason (I think): The first series of the 6 speed R1150 bikes got installed the gear indicator switch from the R1100 5 speed - they must have had a few left over. When gear changed to sixth, it didn't know what to do so it showed E for error. Link to comment
smiller Posted November 9, 2009 Share Posted November 9, 2009 The real reason (I think): The first series of the 6 speed R1150 bikes got installed the gear indicator switch from the R1100 5 speed - they must have had a few left over. When gear changed to sixth, it didn't know what to do so it showed E for error. OK, don't hate me for being such a weenie but... the output of the R1100 gear selector switch is in BCD format (binary coded decimal, which represents the numerals 0-9 by which of four lines are on or off.) The switch only has three lines so it can only indicate up to eight positions, but that's still plenty. I guess it's possible that the switch didn't have enough internal contacts so that if it rotated too far it provided a 000 output, but in that case BMW could have just interpreted that as 6th gear. I wonder if perhaps it wasn't the switch that was the problem, but rather they were using some leftover RIDs. If the RID wasn't programmed to know what to do with the unexpected digit, that might cause the 'E' output. Link to comment
tallman Posted November 9, 2009 Share Posted November 9, 2009 OK, then it is probably a result of hard braking that slid the binary code display from bottom to top. Yeah, that's the ticket. Link to comment
Paul Mihalka Posted November 9, 2009 Share Posted November 9, 2009 The real reason (I think): The first series of the 6 speed R1150 bikes got installed the gear indicator switch from the R1100 5 speed - they must have had a few left over. When gear changed to sixth, it didn't know what to do so it showed E for error. OK, don't hate me for being such a weenie but... the output of the R1100 gear selector switch is in BCD format (binary coded decimal, which represents the numerals 0-9 by which of four lines are on or off.) The switch only has three lines so it can only indicate up to eight positions, but that's still plenty. I guess it's possible that the switch didn't have enough internal contacts so that if it rotated too far it provided a 000 output, but in that case BMW could have just interpreted that as 6th gear. I wonder if perhaps it wasn't the switch that was the problem, but rather they were using some leftover RIDs. If the RID wasn't programmed to know what to do with the unexpected digit, that might cause the 'E' output. Sounds good. Still something of a carry-over from the 5 speed. Link to comment
NonComp Posted November 9, 2009 Share Posted November 9, 2009 No sixth and no RID. And no temp guage either. And no O2 sensor. Heck, no plastic (well almost no plastic). Sometimes, simpler IS better. Link to comment
Ken H. Posted November 9, 2009 Share Posted November 9, 2009 The real reason (I think): The first series of the 6 speed R1150 bikes got installed the gear indicator switch from the R1100 5 speed - they must have had a few left over. When gear changed to sixth, it didn't know what to do so it showed E for error. I don’t think so, the curcuit board of RID in the 1100 series is entirely different that in the R1150 series, even the one in the ‘02s that showed “E” when in 6th. The chip set is different. Which is why the board could be modified on the 1100 series to do 12-hour clock but on the R1150 series it could not. The "E"conony explanation is more plausible. Link to comment
Al Navecky Jr Posted November 10, 2009 Share Posted November 10, 2009 Will one of the RID's that display "6" work in a 2001 GS? Link to comment
Ken H. Posted November 10, 2009 Share Posted November 10, 2009 Will one of the RID's that display "6" work in a 2001 GS? No, they are not backward compatible. Link to comment
Rocer Posted November 11, 2009 Share Posted November 11, 2009 E=MCsquared (don't know how to type the squared). Whatever you do, hold on - you've got a hottie! Link to comment
SAAB93driver Posted November 11, 2009 Share Posted November 11, 2009 The chip set is different. Which is why the board could be modified on the 1100 series to do 12-hour clock but on the R1150 series it could not. Where is that procedure at for an R1100? I read back when I had an R1100RS that the RID could not be modified to get 12 hr clock but that only the K bike LCD's could. Something to do with the chipset used. Link to comment
Ken H. Posted November 11, 2009 Share Posted November 11, 2009 R1100RS is unique in the that it used the electronics later used in the R1150 series. The R1100RT could be modified though. Link to comment
SAAB93driver Posted November 11, 2009 Share Posted November 11, 2009 The R1100RS and R1100RT show the same part number for the RID on the online microfiche. Link to comment
russell_bynum Posted November 12, 2009 Share Posted November 12, 2009 The R1100RS and R1100RT show the same part number for the RID on the online microfiche. I can confirm that the RID from a 2001 R1100RS is completely interchangeable with the RID from a 2000 R1100RT. (I swapped ours once while I was troubleshooting problems with Lisa's RS.) Link to comment
