noel Posted November 6, 2009 Share Posted November 6, 2009 Hey guys, I'm considering the 5.25" arm on the clutch/brake reservoir. Is this advisable or does it vibrate too much etc? Should I just stick with the 3.5"? Link to comment
10ovr Posted November 7, 2009 Share Posted November 7, 2009 If you just put the 5.25" arms on with nothing on them,,They should be fine ,,Mite help to know what you are mounting on them????????? Link to comment
noel Posted November 7, 2009 Author Share Posted November 7, 2009 Silly me! Zumo 660 is the item I'll be mounting. Link to comment
10ovr Posted November 7, 2009 Share Posted November 7, 2009 I would say it would work,,It may move if you hit a hard bump....There are better mounts to mount you 660 on,,More solid... Link to comment
bobbybob Posted November 7, 2009 Share Posted November 7, 2009 I use the shortest Ram length available for my clutch reservoir. Anything longer is just too long. I bought the longer and tried it but it just got in the way. Link to comment
noel Posted November 7, 2009 Author Share Posted November 7, 2009 Just too long? No excessive vibration or moving out of position due to a bump or something? Link to comment
bobbybob Posted November 8, 2009 Share Posted November 8, 2009 Nope, no vibes or movement--just too long--sticks up too high. Link to comment
Edgar Posted November 8, 2009 Share Posted November 8, 2009 The 5.5" arm works just fine. It puts the device up high enough so you can see it without moving your head. Link to comment
noel Posted November 8, 2009 Author Share Posted November 8, 2009 Thank guys. I truly appreciate the info you have provided. Cheers. Link to comment
Unhofliche_Gesundheit Posted November 10, 2009 Share Posted November 10, 2009 another vote on the shorter arm. i have 3.5" mounted on the clutch res. cover and i would prefer it LOWER (more protected - i have a tomtom one for cars and it is not waterproof..) the speedo and tach are pretty low... as long as gps is above that level imho all is good. as an aside the ram mount looks very flexible but it pivots and swivels a lot less than i thought it would. still fine however. Link to comment
