Rinkydink Posted November 6, 2009 Share Posted November 6, 2009 Do the battery cables on an 04 RT bolt right up to the PC680? I seem to remember reading about some mod having to be made. I couldn't find anything through a search... Link to comment
smiller Posted November 6, 2009 Share Posted November 6, 2009 There are some L-bracket connectors available to adapt to the flat terminals on the PC680, or you can just bend the terminal lugs on the bike's battery cables flat and that works fine too. Link to comment
flat_twin Posted November 6, 2009 Share Posted November 6, 2009 I made L brackets for mine. I read a thread where someone mounted the battery sideways to avoid having to use brackets. Link to comment
NoHeat Posted November 6, 2009 Share Posted November 6, 2009 Maybe this L-shaped adapter? FWIW, I found that using this site's search feature with keywords +pc680 +terminal. Link to comment
RT Russ Posted November 6, 2009 Share Posted November 6, 2009 So....is the Odyssey a highly recommended battery for an 02 RT? I'm on the verge of needing a new battery and haven't started any serious research yet. Link to comment
Selden Posted November 6, 2009 Share Posted November 6, 2009 The Odyssey I bought from Batterymart.com in May came with L brackets. I put a piece of 3/8" closed cell (camping sleeping pad) foam between the strap and the top of the battery to snug it down a little. Prices have gone up a little since spring; best price at this instant seems to be from Amazon. I bought my Odyssey from Batterymart.com BatteryMart.com, which currently lists two batteries for an RT. Interestingly, the Odyssey is rated at 16 Ah/220 CCA and the ProSonic at 19 Ah/190 CCA. I like the way their web site was organized, as well as the price. I was also reassured that there was an actual bricks and mortar store in addition to the web site. Battery threads are like oil threads... Link to comment
smiller Posted November 6, 2009 Share Posted November 6, 2009 So....is the Odyssey a highly recommended battery for an 02 RT? Yes it is, top quality but relatively pricey. Many are also using the generic UB12220 (available from many vendors for under $50, Google for it) with good results so far. Link to comment
outpost22 Posted November 6, 2009 Share Posted November 6, 2009 There are some L-bracket connectors available to adapt to the flat terminals on the PC680, or you can just bend the terminal lugs on the bike's battery cables flat and that works fine too. Yep, my battery came with the brackets. Just bend them to fit. I think the brackets had to be drilled out slightly to accommodate the bolts. Just make sure of the tupperware clearance. I had to bend mine a few times for the correct clearance. The PC680 has been flawless since February 2008. No ABS faults either. Link to comment
Polo Posted November 6, 2009 Share Posted November 6, 2009 When I installed the Odyssey battery on my RT I just bent the brackets. No need to go spending gas money. Link to comment
11101110 Posted November 7, 2009 Share Posted November 7, 2009 You could also make your own using .125" thick by .75" copper stock. Then you would have plenty of room to add extra wires for farkles. The less capacity a battery has the less its internal resistance. the less its internal resistance the more amps you can get from it. Link to comment
Eckhard Grohe Posted November 7, 2009 Share Posted November 7, 2009 I have a PC680. Use the bike 3 times a year nowadays and charge it twice to keep it fresh. Discharged once down to 5 volts and charged it up with a 10 amp charger as per Odyssey specs. then I trickle charged it for 2 days. This was 3 years ago. My battery is at least 5 years old. One tough battery.. Costs more but worth every penny. Link to comment
Mark K Posted November 8, 2009 Share Posted November 8, 2009 You could also make your own using .125" thick by .75" copper stock. Then you would have plenty of room to add extra wires for farkles. That's right. I just cut some 1/2" copper pipe, pounded it flat, bent it and drilled two holes in each. Link to comment
11101110 Posted November 8, 2009 Share Posted November 8, 2009 You could also make your own using .125" thick by .75" copper stock. Then you would have plenty of room to add extra wires for farkles. That's right. I just cut some 1/2" copper pipe, pounded it flat, bent it and drilled two holes in each. I like that Idea. My copper came from a scrap pile at work so just as cheap. Link to comment
breyfogle Posted November 8, 2009 Share Posted November 8, 2009 I also made my own out of 1/2 inch copper strapping ... Link to comment
