UKTN Posted August 26, 2009 Share Posted August 26, 2009 Does anyone know the dimensions of the unit that attach's to the side of the helmet. I can't seem to find it in their literature. Link to comment
Rphoto Posted August 26, 2009 Share Posted August 26, 2009 It is oval shaped and at its largest dimension 1 3/4 X 3 1/4. Hope yours works better than ours (we are on our second set and still have lots of static at times). Link to comment
UKTN Posted August 27, 2009 Author Share Posted August 27, 2009 Thank you. What happened to the first unit? Is the static all the time? Link to comment
hopz Posted August 27, 2009 Share Posted August 27, 2009 My Team Set made noise too... when my passenger's microphone got into the windstream. She has a 3/4 helmet with shield and the mike sometimes got pushed down. The VOX activates in the wind noise. Not saying your unit is not making noise- just that ours was fairly quiet except as above. Link to comment
Rphoto Posted August 28, 2009 Share Posted August 28, 2009 It would go into a fit of static for a few minutes (so bad I had to turn the volume down) and then would clear for a time, then do it again. We both wear open faced Nolans with visors so I guess wind noise could be a factor, though we pushed the mikes well out of the windstream. The units have a 1 year warranty so I called Scala and they said to send back the units only (not mounts or accessories_. A week or two later I received them (or replacements back). Same problem, though not quite as bad. My year is almost up so think I will try it one more time. Too much money to put up with this. Link to comment
