ronmelton Posted August 31, 2005 Share Posted August 31, 2005 I'm being told that th battery will not hold ah charge if th GS is ridin for local commuting??????????? TIA ron Link to comment
Ken H. Posted August 31, 2005 Share Posted August 31, 2005 I'm not sure how whomever said that defines "local commuting" but I use mine for day-to-day around town stuff most every day and haven't had a battery issue yet. Link to comment
David Posted August 31, 2005 Share Posted August 31, 2005 Ken, he asked about a GS, not an RT. Link to comment
Marty Hill Posted August 31, 2005 Share Posted August 31, 2005 Ron, Can't believe that. I ride mine about 12 miles to starbux every day when I'm in town. No issues with the battery. David, Ken can be proud of having the only 1200 GS/RT on earth. Link to comment
ronmelton Posted August 31, 2005 Author Share Posted August 31, 2005 Thanks for th replys, i wuz gittin ah little dissapointed! Ya'll are makin me feel better. Marty my wife's sister lives in Kennesaw. Link to comment
Jeff98362 Posted September 2, 2005 Share Posted September 2, 2005 You should probably get a spare battery, and just toss it in with all of the other "frequent failure" items on the bike. I think you should store it low in the cases near the spare final drive. Seriously, I have found mine to be a bit slow to crank if it sits for two weeks. I am careful to turn off the high-beam and go easy on the brakes while I drive through my development, hopefully conserving juice and leaving more to be saved in the battery. I have not commuted every day since I had the RT, but I have experienced no problems with the GS battery so far! On another related topic, my dealer found a loose battery connection caused a sensor to read a parameter incorrectly, which caused a "fault" which caused the bike to run erratically (throttle up and down). Tightening the terminals and clearing the fault fixed it. CHECK THOSE CONNECTIONS FREQUENTLY! Link to comment
eric2 Posted September 2, 2005 Share Posted September 2, 2005 No, it charges fine in urban/stop n go driving. Eric Austin r12gs Link to comment
k12steve Posted September 3, 2005 Share Posted September 3, 2005 I'm being told that th battery will not hold ah charge if th GS is ridin for local commuting??????????? TIA ron Untrue! But my dealer is convinced that leaving the key in the bike will eventually flatten the battery due to its constantly "talking" to the bike's computer. Anyway...no problems with my GS, ever. Link to comment
ClearwaterBMW Posted September 3, 2005 Share Posted September 3, 2005 when i picked up my new 1200GS, my battery was almost dead. at the time we attributed that to the fact that my aftermarket horns were so loud that many in the service bay were obsessed with "listening" to them so much that the battery was drained it holds a charge fine but, one thing i've noticed (and maybe this is normal - please enlighten me, if you would)... WHEN COLD, the bike NEVER starts on the first try i have turned it on and waited for the fuel pump to go quiet... etc the 2nd try, starts right up. is this some characteristic of EVERY 12GS, or just some quirk of mine that might be secondary to the initial battery issue? thanks in advance, as always greg Link to comment
Ken H. Posted September 3, 2005 Share Posted September 3, 2005 is this some characteristic of EVERY 12GS, or just some quirk of mine that might be secondary to the initial battery issue?Are you waiting for the full boot sequence to complete, the yellow caution light to go out, before the first start attempt? Link to comment
ClearwaterBMW Posted September 3, 2005 Share Posted September 3, 2005 yes, i did wait for that whole boot sequence does your's ever do that? greg Link to comment
steveknapp Posted September 4, 2005 Share Posted September 4, 2005 WHEN COLD, the bike NEVER starts on the first try I never wait for the boot sequence (f'that), and mine almost always starts first try. Haven't had it in the 30-40F type cold yet. Link to comment
ClearwaterBMW Posted September 4, 2005 Share Posted September 4, 2005 anyone else with a story to tell just tried it again it's been sitting for about 6 hours waited for the whole boot sequence turns over well/battery is plenty strong doesn't start 1st time stop.... wait 2 secs restarts... fires IMMEDIATELY anyone else? greg Link to comment
Ken H. Posted September 4, 2005 Share Posted September 4, 2005 Mine seems to be just the opposite. If I don't wait for the boot sequence to finish it is harder to start. Go figure... Link to comment
ClearwaterBMW Posted September 4, 2005 Share Posted September 4, 2005 today, i realized that it will start up cold on the first try if i have the clutch lever pulled in. that is the suggestion in the manual for COLD STARTING. of course, it's 95 here today. i guess with the clutch pulled in there is less "pressure" on the starter to turn the bike over with less fuel in the bowls (of course, i don't know crap about anything about this... and i'm sure that others will point that out to me) but.... with the bike in neutral, and still sitting on its sidestand in my garage... with the clutch pulled in.... she started RIGHT up go figure that greg Link to comment
ShovelStrokeEd Posted September 4, 2005 Share Posted September 4, 2005 Really has nothing much to do with battery charge (withi reason) or waiting for sequences or any of that stuff. The pulling in the clutch thing will help the spin rate a bit by removing the drag of cold gear box oil from the starter. Yes, 95 deg F. is cold to gearbox oil. 40 is even colder though and it is good practice in cold climates to pull in the clutch on a cold start. When the injectors fire is related to the crank position sensor(s) and how many pulses they see as compared to how many the Motronic needs. Other factors might come into play regarding where your idle bypass motors came to a stop. This might be software version related as well, causing bikes from different build dates to behave in very different manners. I doubt BMW will reveal any more about this than they have done about Motronics of old. It wouldn't surprise me if emission regulations have removed the old tried and true pulse a good squirt on the first trigger pulse so long as the starter button is depressed. Lessee, our injectors are probably rated somewhere about 32 GPH static flow. A pulse of say 40 milliseconds, which would be long for a cranking pulse would give,,,,, sounds of calculator buttons clicking,,,,,3.55 e^-4 gallons or 1.94 cc of gas per injector 2.7 mL of gas total of which some is likely to burn. We have once again, saved the enviornment! Link to comment
ClearwaterBMW Posted September 5, 2005 Share Posted September 5, 2005 thanks for that explanation, ed the geek in me (and there's plenty of him) really enjoyed that bit of learning greg Link to comment
