Buccaneer Posted August 27, 2005 Share Posted August 27, 2005 Hi all I found a local source for anodised aluminium hex bolts, which I would like to use on the fuel cap filler thingy. The parts list gives the bolts as M5x28. I can get M5x25 and M5x30. Does anyone know which of these would fit best, or am I going to have to grind a set of 30s down 2mm? The reason I ask is I have to order by mail, so I can't simply test one of them. Link to comment
RodB Posted August 27, 2005 Share Posted August 27, 2005 What's the problem with the ones that came with the bike? Link to comment
Buccaneer Posted August 27, 2005 Author Share Posted August 27, 2005 Nothing at all - I want to replace them with red ones. Fast becoming a compulsive cusomizer.... Link to comment
Joe_Rocket Posted August 28, 2005 Share Posted August 28, 2005 Were it me... I'd simply order enough of each size and use whatever works. I wouldn't think they would be that expensive. JW Link to comment
Clive Liddell Posted September 1, 2005 Share Posted September 1, 2005 The parts list gives the bolts as M5x28. I can get M5x25 and M5x30. Does anyone know which of these would fit best, or am I going to have to grind a set of 30s down 2mm? When I wanted to remove and replace the tank fairing on my 11RT I couldn't get the original bolts to "take". I have since found that part of the problem was the swelling of the O-ring. BUT, I also found that "they" had used 25mm bolts. I got some 30mm stainless steel bolts and cut them down to ~27,5mm. Then I saw the proper size in the parts list . The 30's bottomed out onto the tank on my bike... Link to comment
