Conti-RA's front directionality
BOXDAWG
Posted
Getting ready to mount new conti road attacks. The front tire has an arrow on the sidewall going one way and smaller arrows on the side of the treads going the other. Which way am I supposed to mount it
Posted
It's the main one you go by, the smaller ones are purely cosmetic, there has been some similar confusion over here in the UK where a few have been fitted wrong.
Posted
So the sidewall aroows are correct then. Thank's for the quick reply
Posted
The RA's cause confusion at a lot of shops!
The rear tire has the "pointy" end of the tread pattern on the tyre pointing forward as you look at the tire from the rear.
The front tyre has the pointy end of the tread pattern facing the rearward!
Posted
Someone explained this (for another tire) in a way that I understood last year. Think about the loads on each tire: the front tire has to handle braking forces, and the rear (mostly) has to handle acceleration forces. Therefore, the treads should work in different directions.
Posted
If you look at the Conti rain grooves, the front tyre tread is designed to "push" the water out of the way of the rear tyre :thumbsup:.
