Fightingpiper Posted May 8, 2009 Posted May 8, 2009 Got home last friday from my trip to the South East. Broken windshield strut, Zumo quit taking charge from bike, Radar detector audio out broke, order new rear tire and I found this hose loose on the upper right side of the bike. I can't find anywhere where it should be connected. Any thoughts?
Buckster Posted May 8, 2009 Posted May 8, 2009 Looks like the fuel tank vent hose to the vapor cannister. Should connect to a hose just forward and to the right of the fill cap. No harm other than the fumes venting to the outside rather than into the vapor cannister to be sucked into the engine when running. Buck
10ovr Posted May 8, 2009 Posted May 8, 2009 Yup,Thats what it is,Be sure not to pinch it when you install the tank,,,
RT Fan Posted May 10, 2009 Posted May 10, 2009 The connector for that hose is on the outside (tank side) of the radio case. It is down near the bottom of the case. You can see the mating connector if you look with a flashlite from the front of the bike. Look down near the bottom of the radio case and you should see it.
