Spark Plug Numbering for R12
Albert
Posted
I changed my plugs last night and noticed one oddity. The plugs I removed were OEM, Bosch R6. The new plugs are NGK DCP R8EKC. The NGK seems to be correct (based on what I can find) but I can find no reference to Bosch R6. Physically the plugs are identical. Any thoughts? TIA.
Posted
Albert, not sure what you have there.. You sure there aren’t more numbers on those removed Bosch plugs.. Bosch R6 doesn’t tell us much other than heat range..
Twisty
Posted
Hmm I'll look again Twisty but I didn't see any. There did appear to be a small symbol after the R6 but maybe there's more. Thanks.
Posted
Albert, if no more numbers up on the porcelain look down on the side of metal base..
Twisty
Posted
Gotcha, thanks.
Al
