Help W/ R1200C
Beembish
Posted
A friend of mine has a '98 R1200C. He wants to put in a new battery and air filter. Does the gas tank have to come off to change them. He said he will have to disconnect the fuel lines and lift the tank off.
Is this true?
Any suggestions?
Posted
You are correct on lifting the tank. On my 98 I had to pinch off the gas lines and lift the tank. Not too bad of job, tho the first time is always the most time consuming and challenging. Good Luck.
