Micky Posted August 14, 2005 Share Posted August 14, 2005 Need some tips to replace the final drive oil seal. Not to long ago someone posted some excellent pics of a dismantled final drive. I like to see them again, but cant find it now. Thanks, Micky 2000 1100RT Shoreline, WA Link to comment
Les is more Posted August 14, 2005 Share Posted August 14, 2005 Not sure if this is what you mean but here's a link I found by using the search funtion, searching the Oilheads Forum with +final +drive +picture Good luck. Link to comment
Micky Posted August 14, 2005 Author Share Posted August 14, 2005 That is the one I was looking for, Thank you, Micky Link to comment
Micky Posted August 16, 2005 Author Share Posted August 16, 2005 I changed the oil seal today. Total cost $ 21.42 , that is the seal and an o ring. Total time was less than three hours. It was a very simple job . 3 k miles ago I had a very weird problem, a piece of rock fell into the space between the disc and the final drive housing. It made a lot of noise, I thought first it is the crown bearing. We were on a trip in the Sierras, 15 K mile from home. So I took the wheel, the caliper, the rotor off in a motel parking lot, and cleaned out the broken up pieces of stone. But it made a damage to the seal, as the rock was milled to pieces between the disc with the ABS ring and the housing cover. The bike has 44 K miles, and the crown bearing is just perfect. I use Amsoil 75W 140 synthetic gear lube, and the lubricant looked clean as honey after 10 K miles. Mickey Shorelie, Wa 2000 1100 RT Link to comment
