DaveyMac Posted August 13, 2005 Share Posted August 13, 2005 With No CCP is an "00" 1100rt run in open loop or closed? Dave Link to comment
ShovelStrokeEd Posted August 13, 2005 Share Posted August 13, 2005 That depends on the O2 sensor, not the CCP. It is in turn dependent on throttle position. CCP deptermines which base map to be modified by the various sensors, lack of CCP is just a different map. Open/closed loop is dependant on throttle opening and RPM range. Engine is closed loop at moderate (up to 13% throttle opening) and low RPM < around 4.5K. Above that and at idle engine runs open loop. Link to comment
Paul Mihalka Posted August 13, 2005 Share Posted August 13, 2005 It is open loop, it ignores the oxygen sensor. It expects the input of a manually adjustable "CO pod". If not present, it goes into a fallback program that is not that bad. No CCP and installed CO pod was the standard form on European/Canadian bikes from '96 to ??. Link to comment
Clive Liddell Posted August 13, 2005 Share Posted August 13, 2005 In SAfrica I think all the R1100 series were "no cat" and CO adjustable bikes - thats why I acquired one of the last 1100RT's on the floor. I had to push my way through a forest of new R1150RT's to view "my" bike and I've never regretted it. Link to comment
DaveyMac Posted August 13, 2005 Author Share Posted August 13, 2005 Thank You, So no CCP, Default fuel Map correct? With No sensor imput corrections? Do I have it right Link to comment
ShovelStrokeEd Posted August 13, 2005 Share Posted August 13, 2005 No, that is wrong. You still get sensor input corrections just none from the O2 sensor because the ECU no longer expects an O2 sensor input. All the other sensors, TPS, air temp, barometric pressure, oil temp still work and modify the base map output. None of the other sensors provide feedback as to the mixture thus the system is still "open loop". Link to comment
