hieronymous Posted February 14, 2009 Share Posted February 14, 2009 The very limited tool kit provided by BMW does not includes an adapter to remove the quick-release front axle on the RT. Here is a pic of my very effective substitute. It consists of a 22mil hex nut welded to a 17mil hex cyclone rod connector. Total cost $2. Link to comment
Dick_at_Lake_Tahoe_NV Posted February 14, 2009 Share Posted February 14, 2009 And for about the same price you can buy a 22mm Hex Bolt from ACE hardware, and two nuts to go on it. Then turn the nuts to lock them together. Link to comment
lvnvbiker Posted February 14, 2009 Share Posted February 14, 2009 I used the larger of my sparkplug sockets turned backwards. The hex part fit perfectly and after pulling out the rubber thingy a 4 inch extention allows the rachet to be used. Oh the socket is a Craftsman 13/16ths sparkplug socket the hex end is 22mm. Link to comment
Huzband Posted February 14, 2009 Share Posted February 14, 2009 You guys are missin' out. I spent a meager $17 for a hex key at a local tool supplier. Link to comment
SWB Posted February 14, 2009 Share Posted February 14, 2009 You guys are missin' out. I spent a meager $17 for a hex key at a local tool supplier. Whew! I just knew there had to be a better way. All this tool talk - too technical! - Scott Link to comment
MSmith Posted February 14, 2009 Share Posted February 14, 2009 Did a search on eBay for a 22mm hex tool and found this for $8.00. Bought it and it works fine. Search eBay for item number 290290545516 No affiliations, other than a satisfied customer. Link to comment
archie Posted February 14, 2009 Share Posted February 14, 2009 i got a 22mm allen key and cut it up, then use a 22 socket on it,this way you can make several tools and give them your mates. archie Link to comment
lvnvbiker Posted February 15, 2009 Share Posted February 15, 2009 Sparkplug socket 6.50 and it works as well a sparkplug socket on one of my other bikes... Link to comment
Lone_RT_rider Posted February 15, 2009 Share Posted February 15, 2009 This is the one I use.... Shawn Link to comment
Rider1200RT Posted February 17, 2009 Share Posted February 17, 2009 Nice tool, but isn't it rediculous that B-ring M-ore W-allet doesn't supply the basic tools such as a lug wrench for the rear wheel bolts or a front axle tool. Link to comment
bimmers Posted February 18, 2009 Share Posted February 18, 2009 cycle gear has a tool for that. Don't remember price but not over 20 in any case. Easy to get and use. It has like three different sizes of external nuts and internal 3/8 I believe. Link to comment
